Can't get calipers apart
I have a 1970 small block. Have had it for 25 years and never had to do anything with the brakes. Figured it was well due to give them some love. So I was going to rebuild the calipers and master cylinder and replace the rubber lines with stainless flex lines. I also started experiencing that when I brake, the car pulls pretty hard to the left... I assume that means the front right caliper may not be working?
Got the calipers off the car.. But I can't break the bolts free that hold the caliper halves together. What seems strange is there is not room to put a socket on those bolts, so I have to try to break them free with an open ended wrench? They are so tight. I'm afraid I'm going to round off the corners. Does this sound right? Should I be able to get a socket on them? I'm wondering if these are not original calipers? Maybe previous owner changed them?
Any ideas/suggestions of how to get them separated?
that s with oem ones....no clue what you have but again pic helpful..
personally other than hoses less than 10 years old and leaks..i dont mess with anything..
every other year brake bleed/ flush..
also my lesson learned...go with o ring kits..lip seals for me were 50/50
good luck!
Thank you all - stay healthy!
Metrinch is a computer designed tool line that grips and drives the nut only on the sides, not using the corners at all, so no danger of rounding the corners of any fastener. I have seen other sockets and wrenchs that also drive by the flanks, and not the corners, but don't remember the names. The metrinch stuff works on both metric and SAE with the same tool, a benefit of the design. The only drawback is that the sockets will fall off the nut, unlike a tool with a tighter fit that grips the corners. I'm a fan of the stuff, liking most space saving stuff in general, plus I never have to figure out what standard the stuff I am repairing is built with.
This reminds me of a story, if you have time.
I used to sail into Valdez Alaska , where, besides the oil pipeline as the attraction, there is a seasonal tourist trade , fishing for big halibut. There also was an airboat that ran out to the glacier. Unfortunately for the airboat, it was left unattended , and the tides had the thing captured underwater for some time. Once the ice thawed, the control surfaces no longer moved when it was recovered, and the vessel was abandoned on the mud flats . A local used to pass by this wreck everyday, and started to apply penetrating oil to the control rams, every day as he passed by on his daily walks, a couple of drops and an attempt to move the wings. In time he got the control wings to wiggle a bit, and with more time, full function of the control surfaces was restored, and he got himself a "free" flying boat. The complete repair details were not discussed when the story was told to me, I never saw the owner, but it did make me a believer in liquid wrench and those types of products.
... That is exactly how I do it, break them loose on the car than remove them from the spindle. Reassemble them when done and then remount them on the spindle to torque them to spec.Good luck... GUSTO
