How to remove lower control arm bushings???
Old Dec 2, 2020 | 05:38 PM
Jd21476's Avatar
Jd21476
Default How to remove lower control arm bushings???
I have watched a few videos and everyone makes it looks fairly easy. I burned off all the rubber, sprayed the bushings, and tried to drill out the rubber. I have been beating on the bushings with a hammer for about half the day and none of them have budged even and inch. What do I do?
Old Dec 2, 2020 | 05:59 PM
interpon's Avatar
interpon
see post 6
https://www.corvetteforum.com/forums...rs-method.html
Old Dec 2, 2020 | 06:36 PM
reno stallion's Avatar
reno stallion
C2 of Year Finalist (appearance mods) 2019
Pry outward as the chisel starts to go behind the bushing
Jd21476's Avatar
Jd21476
Ok, so I went to Harbor Freight and bought an air hammer. Hope it works.
Now, since I am switching from rubber to poly, do I reinstall the large washer in the outside of the upper bushing or
was that only for rubber?
Old Dec 2, 2020 | 06:38 PM
resdoggie's Avatar
resdoggie
Had a 1976 L-82, 4-sp
Royal Canadian Navy
Yep, air chisel makes for short work.
Old Dec 2, 2020 | 06:47 PM
reno stallion
I would not use poly bushings
Old Dec 2, 2020 | 06:53 PM
Vette5311's Avatar
Vette5311
Put the large washer back on. It keeps the bushing from working out of the shell.
Old Dec 2, 2020 | 07:08 PM
Jd21476's Avatar
Jd21476
Thank you all
Old Dec 2, 2020 | 10:14 PM
Jd21476's Avatar
Jd21476
The air chisel definately did the trick. They came out pretty easy but I dont think I would have succeeded without it.
Now how do I put the new ones in. I tried to hammer them in and I tried to use a washer and bolt with a nut to pull them through but they wont budge.
whats the best way?
Old Dec 2, 2020 | 10:19 PM
reno stallion
You need a press but you also should have a fixture to keep from crushing the socket.
Old Dec 2, 2020 | 10:20 PM
Jd21476's Avatar
Jd21476
What kind of fixture? Im going to hit up Harbor Freight tomorrow for a press
Old Dec 2, 2020 | 10:27 PM
reno stallion
A piece of pipe that fits tight between the inside ends. Youtube it
Old Dec 3, 2020 | 08:50 AM
resdoggie's Avatar
resdoggie
Royal Canadian Navy
If your careful, you can use a vice and not need a fixture for the poly bushings. Make sure you use lots of lube on those bushings.
Old Dec 3, 2020 | 10:04 AM
reno stallion
This is correct if you are going to use the poly then you shouldn't need a press
Old Dec 5, 2020 | 05:10 AM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
agreed. I have poly. sanded the inside of the bushing holes to c lean them up. oil, and tapped them in lightly. plenty of loc-tite on the bolts!
Old Dec 6, 2020 | 01:49 PM
lars's Avatar
lars
If you're using the stock-type rubber bushings (highly recommended), you don't need a press. You buy a cheap Chinese-made 3/4" drive socket set from Harbor Freight. You use the sockets as mandrels, and simply tap the bushings into the a-arms using your socket and a hammer.
Clean up the bushing bores really well with sandpaper or a rotary sanding roll:
Always measure the finished ID of the control arm holes and the OD of your new bushings to make sure you only have a few thousands interference fit:
With 2 to 3 thousands interference fit, the bushing will easily hammer in using your socket set and a hammer - the a-arms will not be damaged, and you can do each bushing in a few seconds. Lube the shafts and stick them in:
Finish up by installing the retaining hardware. For a street driven car, the stock rubber is the way to go. You gain nothing using poly. Around half of all a-arm rebuilds I do simply involve removing customer-installed poly bushings and installing stock rubber after people get sick of the feel and noise of the poly:
Lars
To How to remove lower control arm bushings???
