A6 compressor brackets
Old Dec 4, 2020 | 07:36 PM
teamo's Avatar
teamo
Default A6 compressor brackets
Reassembling the AC system on my 1975 Coupe. The diagrams in the AIM are ok but not detailed enough. The adjustment brackets that mount to the compressor on the front and rear have a flat machined surface on one side and a slightly rounded off surface on the other side. Which side goes towards the compressor? Also the bolt description in the AIM is not that good. Some bolts show lock washers and some show just the nuts against the bracket.
