Under dash braces
Old Dec 4, 2020 | 07:41 PM
teamo's Avatar
teamo
Default Under dash braces
I've done a lot of reading on the under dash braces and it is still not clear. Does the coupe get the braces? The AIM shows the code for convertible and ac. Is this convertible w/ac only or convertibles and all cars with ac? It appears that I don't have any remnants of the transmission tunnel bracket that mounts the under dash braces but there have been so many repairs by previous owners that I don't really know if they were glassed over. From what I've read it seems to be the majority of the under dash braces were for convertibles only but I have seen online information by owners of coupes that say that their cars are all original and have the brackets.
Old Dec 4, 2020 | 07:48 PM
Shovels and Vettes's Avatar
Shovels and Vettes
The coupes do not have braces. Only convertibles. The upper corner gussets, where the braces bolt to, are used on both coupes and convertibles.
Old Dec 4, 2020 | 08:42 PM
Richard454's Avatar
Richard454
However if your vette was built on Friday- it might not have braces too!!!
The AIM says only on verts- but the reason the t-top came about was the original targa idea had too much flex.
The braces did not use the transmission saddle on non-AC cars.
There are several that have added the braces on the coupes- And on my vert- I added some support on my bracing too.
Certainly wouldn't hurt.
Richard
Old Dec 4, 2020 | 11:04 PM
Gale Banks 80''s Avatar
Gale Banks 80'
What are You referring to as the Transmission Saddle ? If it doesn't have the Saddle then what do the braces attach to ? I have a 69 Vert that has assembly marks " AC" below the Heater Core on the Engine side and also has "AC" behind the Drivers Seat. Many people seem to think that only the Big Block cars got the braces has that been proven to be a myth ?
Old Dec 4, 2020 | 11:31 PM
Richard454's Avatar
Richard454
Here you go-
AC
Non- AC no bracing to the transmission
Old Dec 5, 2020 | 12:28 AM
Gale Banks 80'
Thank You well done
Old Dec 5, 2020 | 12:05 PM
teamo's Avatar
teamo
That clears a lot up. Not sure why they would make a distinction between ac and non ac convertibles. Wouldn't they have the same issue with the body flexing without the roof regardless of whether it had ac or not? I am thinking of adding the braces to my coupe but the transmission saddle is not reproduced. I'll keep my eye out for a good used one.
Old Dec 5, 2020 | 01:56 PM
Shovels and Vettes
Default Reason
The reason there is a difference is that AC cars have stuff in the way that the Non AC cars do not. I suppose they could have used the same setup that is used in AC in non-AC cars.....but its probably the fact that AC is an option....and the original braces were based on a standard car,...without AC. Not sure.
Old Sep 6, 2024 | 02:27 PM
Gale Banks 80'
Originally Posted by Richard454
Here you go-
AC
Yes, its an old thread but I have a new question. The right-side Bar in the above picture is bolted to a Bracket. I assumed it was welded in but I see threaded holes in my birdcage right where it should go. So, shall I assume that it is a bolted in Bracket? I am referring to the far-right lower side. Not the Spot Welded Bracket that is on the upper left. Wile were at it does anybody have a picture of the Rod on the Left Side ? The one that goes from the Steering Colunm to the upper spotwelded Braket ? In the AIM this looks like one of the solid Rods, and not a Tube like the right side. This is all pertaining to a 1969 Convert with out AC.
Old Sep 7, 2024 | 12:11 AM
Dagious's Avatar
Dagious
Another question. Anyone who has installed Vintage Air in a convertible, did you reinstall the braces? I had to remove the front tunnel brace to install the VA evaporator unit. I could install the rear brace with the evaporator in place, but then could not install the right side dash.
Any thoughts?
Old Sep 9, 2024 | 05:41 PM
vettebuyer6369's Avatar
vettebuyer6369
Rather than asking a new question in an old thread, please start a new thread with your new question. Thanks.
Old Sep 9, 2024 | 05:42 PM
vettebuyer6369
Any thoughts?
Yet another new question. Perfect for a new thread.
To Under dash braces
