Tips for freeing up a motor
Old Dec 15, 2020 | 08:20 PM
62corvette's Avatar
62corvette
Default Tips for freeing up a motor
Original 454 sat for 35 years and won’t turn with a breaker bar on the crank bolt. Plugs are all removed—no problem with coolant in any cylinder. Coolant clear and green.
What to use and how to go about freeing it up? Prefer not to pull the heads, and prefer not to spend money on machine work. 51,000 miles on very original motor.
Looking for tips. Marvel Mystery oil in cylinders? Diesel fuel/atf mixture in cylinders?
Old Dec 15, 2020 | 08:39 PM
Greg's Avatar
Greg
Just another Corvette guy
I have freed up a couple of stuck engines using PB Blaster. I used two full cans and just drenched the cylinders. On engine stand so I was able to shake them everyday for a little agitation. 1 week, both broke loose.
I know others have used many different mixtures of oils, mystery oil, ATF, diesel, etc. And having used all of those as well over the years, I found the PB Blaster did the best job in the shortest time.
Good luck brother.
Old Dec 15, 2020 | 08:41 PM
centuryoldracer's Avatar
centuryoldracer
I have dealt with this, and fill them completely full of either drained (used ) motor oil or diesel or a mixture of both. Fill it to the top of the valve covers on both sides, and fill every cylinder through the spark plug holes, also fill the intake manifold and all the exhaust ports. On the exhaust ports with open valves put the spark plugs back in, and fill it through the exhaust port so the cylinder is completely full on top of the piston.
Depending on how bad it is, it still probably won't turn, but I have had limited success letting it sit this way for a couple of months.
Old Dec 15, 2020 | 08:43 PM
centuryoldracer
Good luck brother.
WD-40 also has a product that dissolves rust that works pretty good
Old Dec 15, 2020 | 09:15 PM
cv67's Avatar
cv67
St. Jude Donor '05
All good suggestions, never thought about adding more oil like century racer said
To avoid breaking the head off your bolt or stripping it try using a flexplate wrench from underneath you have more leverage
35 years is a looong time wow
Old Dec 15, 2020 | 09:28 PM
Dirty Dalton's Avatar
Dirty Dalton
Fortunately for me, no personal experience. Some swear by Kroil. I have used it on another application (a very rusty threaded steam coupling) with success. Another is 50/50 mix of ATF/Acetone. No experience there.. Good luck!
Old Dec 15, 2020 | 09:33 PM
Vette5311's Avatar
Vette5311
1st off forget about the balancer bolt for turning the engine. Take the lower pulley off. Get a bolt on adaptor, I like Marvel Mystery Oil. take off exhaust manifolds so you can get at the spark plug holes more easily. Fog or mist the cylinders once or twice a day for a week or more. Then try to rotate the engine in the opposite direction to break it loose. Rinse and repeat as necessary.
Old Dec 15, 2020 | 10:58 PM
centuryoldracer
Also have it sitting in a catch pan as you are going to know where every leak is using my method which can be messy
Old Dec 15, 2020 | 11:01 PM
cv67's Avatar
cv67
St. Jude Donor '05
once filled Dads 73 Impala with a case of oil...he said change it and laid it out so I added em all
Blew the rings and every seal out of it, pronto.
Old Dec 16, 2020 | 09:59 AM
panther-19's Avatar
panther-19
Veteran: Marine Corps
I just did this over this past weekend. Back in October I purchased a 82 CE which had been sitting for more than 5 years. I did not try to key start and the motor would not move with hand torque on the front belts/pulleys. Saturday I used 1 ounce of Marvel Mystery oil in each spark plug hole put the plugs back in loose and let it sit overnight. Sunday I used a 1/2" breaker bar with a 5/8 socket on harmonic balancer center bolt, plugs pulled, torque applied and was getting concerned of breaking bolt head off as the bolt was actually tightening without motor breaking free. I was going to try a strap wrench on the balancer next but pulled one more time on the breaker bar and the motor turned. RELIEF! Next up is pulling the distributor and spinning the oil pump to lube it up before trying to start it. If you use Marvel Mystery oil maybe more than 1 ounce in the 454. Good luck!
Old Dec 16, 2020 | 10:37 AM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
Marvel was always the go-to since I was a kid unsticking dirt bike stuff.......if it will not break loose soaked with Marvel, it is probably too far gone.....
Jebby
Old Dec 16, 2020 | 06:17 PM
Lachymac1's Avatar
Lachymac1
Never tried it but saw this video about a month ago and thought it to be a good idea.
Old Dec 16, 2020 | 08:09 PM
teamo's Avatar
teamo
Patience is your friend here. Remove all spark plugs and fill the cylinders with Mystery Oil. Let it soak overnight. Slowly try to turn the engine with the front harmonic balancer bolt. Don't try to turn it all the way over. A little at a time and add more oil to the cylinders. Keep doing it and it will loosen up. It took me a few days to roll mine over after sitting for 22 years.
Old Dec 16, 2020 | 09:15 PM
cv67's Avatar
cv67
St. Jude Donor '05
you can stick a borescope down the spark plug hole and see if its full of rust before you get started
Old Dec 16, 2020 | 09:20 PM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
One thing I have done is remove the crank pulley and balancer.....put a keyed crank socket (available from Proform for small or big block) and that way you can wiggle the crank back and forth....short movements as too much hair on it will crack the rings for sure.....
Wiggle, Marvel, Beer, Repeat
Jebby
Old Dec 16, 2020 | 10:18 PM
lars's Avatar
lars
Why bothering trying to turn it over..? If the engine is that seized, you're going to have to tear it down and rebuild it. So take the heads off, pull the pan, and then take a 4x4 board and a big hammer to each piston and knock them loose before you remove them from the block. Don't screw around - just tear it apart if your intent is to save it. If you don't intend on rebuilding it, put it back in the corner or sell it to someone who is. Quite simple...
Lars
Old Dec 19, 2020 | 04:11 AM
firstgenaddict's Avatar
firstgenaddict
The last few long time improperly stored vehicles I have been involved were also BB chevrolet's we filled them to the top with motor oil and let it sit for a week or two...
drained and then used a breaker bar with an adapter on the crankshaft snout - uses the keyway.
FWIW - You can use a grease gun with a threaded adapter for the sparkplug... find a cyclinder at the top so as to use the least grease- use the grease gun pressure to break it loose.
To Tips for freeing up a motor
Old Dec 19, 2020 | 07:39 AM
L88Plus's Avatar
L88Plus
Lars
NAILED IT!!! If ring are stuck to cylinder walls, they'll be defective by the time they break loose with corrosion, etc. Even if you get it to turn over and get lucky enough to get it to fire up, you'll kill all the mosquitos within a few miles with rusty cylinder walls and damaged rings. I can almost guarantee rust in any cylinders with an open valve.
Tear it down and rebuild it and save the time you're wasting now.
Old Dec 20, 2020 | 05:40 PM
62corvette's Avatar
62corvette
Thanks for the input everyone. Three days of Marvel Mystery Oil and one pull on the breaker bar from this powerful 74-year-old body and the motor turns over freely.
Old Dec 20, 2020 | 06:25 PM
righthanddrive's Avatar
righthanddrive
Let us know how it runs/smokes once you get it started .
