It's been in the 40's and I noticed the Vette seemed peppier. Tonight I was pulling away from a light and with maybe 25 - 30 mph under my belt gave it probably less than half pedal which I've done before and *whoa* - the wheels broke loose, the rear started to kick out. Got off it and straightened it out. Hmmm, note to self - definitely don't want to do that again. Can the cold air make that much of a difference?
Cold air can be great for power, but jetting changes etc. will be required to optimize the AFR. I wouldn't expect that the cold air is contributing to the power that allows you to spin your tires as much as the road is cold, the tires are cold and you lose a lot of grip. It's still fun don't get me wrong.
Hard to say how much each factor contributed. Looking at flying, in our 4 seat 180 hp Piper Archer, on a hot and humid day, say 100 F and 80% humidity, with 2 people climb rate might be 750' per minute taking off from our airport which is 350' above sea level. Now, go to winter, a crisp 20 F day and 20% RH, and that goes to 1,100 ft per minute. So, a sizeable difference. However, even that is not just power. The denser air increases both the thrust the prop can generate at any given RPM and the lift the wing can produce for a given speed and angle of attack. The only way to isolate the effect on the engine is put it on a dyno and run at different DA's.
Also, no matter how cold it is, I've never gotten the tires on the Archer to break loose when I've hit the throttle.
2016 C3 of Year Finalist
Thats why cld air intakes are a big deal. Normally you are getting really hot air into your motor from under the hood. NOw even the air under the hood hasnt warmed up to the normal above 100* temps so the intake sees a cooler mixture which supports more fuel and if the charge stays cooler, its denser and you can get more air into the cylinder. more air and fuel gives that boost like your getting a 40 hp nitrous boost
IAS is IAS the wing does not know the difference.
The difference is in your ground speed and your true airspeed from air density not the lift generated by the indicated airspeed. The pitot tube is also impacted by less dense air so it is registering a lower IAS for a given GS or TAS due to lack of air density.
Since the wing only knows IAS it is generating the same lift for 80 KIAS (or any given IAS) regardless of the air density.
OP, just as big of an impact on the air density due to temperature is the atmospheric pressure.
These nice cool clear winter days are dominated by high pressure as well. This adds to the air density allowing your engine to ingest more air and thereby more fuel (up to a point with a carb unless jetting changes are made) producing more power per stroke of each piston.
This!!
what you experiencing is lower density alt which means more molocules of air per inch of mercury
Turbo chargers eliminate high density altitude which the engine sees
as far as flying good to know we got some pik
lots here yes IAS must fenain the same at all time in a high density altitude you must increase power or lower the nose to get the same airsoeed you always see. Notice your ground speed is much higher than normal during landing so you eat up mor runway to stop.
Generally speaking yes but you really need to know the DA. There’s also a good chance your tires had reduced grip.
Good DA can make quite a difference, assuming you aren't running lean. Add that to colder pavement with less grip and things can get lively in a hurry. I drove the '69 yesterday shortly before sunset when the temp was about 48 and the DA was 1906 (checked when I got home), which is very good for my location. I got to my usual spot to drop the hammer on a slow 1st gear roll and it was very pissed off....usually the drag radials hook and go but not yesterday. Some tire spin but enough traction to really bolt, with very quick revs through the first 2 gears. It got gone in a hurry!
From: If your not the lead dog the view never changes Boise, Id
‘reminds me of my wife’s favorite joke.
‘do you know how to tell if there is a pilot in the room? .........they will tell you.
QUOTE=RockyL32;1602693631]‘reminds me of my wife’s favorite joke.
‘do you know how to tell if there is a pilot in the room? .........they will tell you.[/QUOTE]
Actually I usually claim to be a dry wall installer. Unless there is another pilot in the room.
Agreeing with a couple of posts above, yes cold air, cold fuel, and cold under hood temps can make a big difference.
For whatever reason I think it’s more noticeable on a milder lower compression motor...summertime at the track can produce a lazier response and slower e.t than earlier spring or late fall passes. Just hot lapping a car with back to back passes can show slower numbers.
and yes, density altitude/barometer plays a big role in all this.
Back in he day when my friend and I went to drag racing tracks, the professionals would put bagged ice on the intake manifold before each run. I don’t know if it made a big difference, but we didn’t the same on my buddy’s small block, caused it looked cool 😎.
I've seen some guys doing that on Street Outlaws.
Fun Fact: The guys with the big brains figured out around the beginning of WWII that injecting water into an engine made for a cooler intake charge. Cooler air means it is more dense (higher volumetric efficiency) and also has a lower tendency to knock (detonation).
If it ran a whole bunch better then there’s a good chance that you are a little rich when the weather is warm
Exactly correct I suspect.
This is the reason CAI works. Especially for carbs.
When you tune your mixture in the garage (not just idle, the mains as well) your doing it at ambient temps of the surrounding air.
Without CAI once you close the hood the temp begins to rise and the air density goes down. That cool looking air cleaner installation that sucks the under hood air is now making the mixture richer by sucking in that hot, less dense air.
The results are a two fold power reduction. Due to not only less dense air, but also improper mixture.
Both great points. Hence there's big value in wideband tuning with the car rolling, which I do. Having the L88 hood adds to that value. This summer I crunched some numbers and realized that the fuel pump I'd been running for many years had been outgrown by recent mods. I upgraded to a pump that could properly feed the engine's new power level and felt a solid gain in power. The way that it reacted to cold air a couple nights ago made me think that it could be a bit fat on the mixture now. I'll retune in the spring and see how it looks with more normal driving temps for where I live.
