Switch
Old Dec 20, 2020 | 09:35 AM
michaelroy's Avatar
michaelroy
Default Switch
Getting ready to replace the combination(proportioning) valve on my 79 L48. been having issues with brakes for a while now. The valve is the only part that has not been replaced on my brake system. I checked the wire running to the valve that illuminates the brake light on the dash. There is no power going to it. I pulled the emergency brake light switch located at the brake handle and the is no power going to it either. I checked after I removed the switch. Does the switch have to be grounded to receive power????? I had the ignition switch on when I checked for power to the emerg. brake switch.
Old Dec 20, 2020 | 09:40 AM
'75's Avatar
'75
The switch grounds the wire during a fault or when the park brake is pulled. The warning light should have power from the gauges fuse, the switch provides the ground.
Old Dec 20, 2020 | 09:43 AM
7T1vette's Avatar
7T1vette
Yep. And there are MANY electrical items in a C3 which have 'switch-activated' grounding circuits. Electric power can be applied by completing the circuit anywhere in that circuit's path: 12vdc power line; the electrical device; or the grounding path.
You can check that circuit out using the ohmmeter function of you multimeter.
Old Dec 20, 2020 | 01:30 PM
michaelroy's Avatar
michaelroy
So if the switch nis bad there is no ground???
Old Dec 20, 2020 | 06:41 PM
'75's Avatar
'75
You can test the circuit by turning on the key and then ground the wire at the park brake switch or the brake failure switch (proportioning valve). I the light doesn't come on, you may have a bad bulb or fuse.
Old Dec 20, 2020 | 08:55 PM
Bikespace's Avatar
Bikespace
There are three ways to illuminate the "Brake" light on your dash.
EDIT: With the key in the ON position, prior to start, the ignition switch grounds the light (so it should illuminate briefly before you start the car).
With the parking brake handle pulled up slightly, the plunger switch will release, close the contact to ground, and illuminate the light.
And the switch in the combination valve also acts as a ground if the plunger is offset to one side or the other.
I none of these work, especially the first one, I'd check the bulb, and perhaps the flexible circuit board at the back of your dash cluster. This was specifically an inspection item that I had to address in my 79 L48.
Old Dec 21, 2020 | 12:17 AM
7T1vette's Avatar
7T1vette
All correct above...except that the light comes on with ignition switch only turned to the ON position (prior to START position). This feature is on ALL vehicles so that the gauge panel bulbs can be tested. If a gauge 'icon' does not illuminate when key is in the ON positon [engine OFF], the bulb is bad.
P.S. For more modern vehicles with push-button [keyless] start feature, the dash bulb test is performed by depressing the start button without your foot on the brake pedal.
To Switch
