Considering adding Fuel injection
Old Dec 26, 2020 | 02:30 PM
fantasygoat's Avatar
fantasygoat
Anyone tested whether the Pro Flo 4 will fit under a stock hood?
Old Dec 26, 2020 | 02:48 PM
Vette5311's Avatar
Vette5311
According to one ad I looked at they offered different manifolds that had different carb pad heights. Going on memory I think the lowest was about 4.8 inches but look it up. My memory is not what it once was.
Old Dec 26, 2020 | 02:53 PM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
I used an old tartantula and added 2 inches of spacers to it and didnt have a problem function wise. But I have the L88 hood for the height.. Worked great all through the range but didnt get a chance to Dyno it
Old Dec 26, 2020 | 03:37 PM
ddsmith60's Avatar
ddsmith60
It looks like you have a L88 hood in the picture. I have a 71 LS5 and I have the 4150 style manifold. It fits with a drop base for the air filter with no hood clearance issues with an L88 hood. I am not sure what the distance difference between the stock 454 hood and the L88 hood to carb base was. A member here used an XT manifold on a small block with an L88 hood and said he had no hood clearance issues.
Old Dec 26, 2020 | 05:42 PM
kossuth's Avatar
kossuth
Originally Posted by Vette5311
I have been considering this also. I purchased an FI tech TBI but have not installed it yet. My question is can you elaborate more on the intake manifold choice. I have a dual plane but am not adverse to a swap to single plane if it will produce better results. Curious minds want to know.
I've never done a swap with a Sniper or similar TBI setup so my experience is based merely on what I've read in various forums and seen on various videos on youtube from folks like Engine Masters etc. So with that said some claim using a spacer can help if you have an issue. Some claim no issues at all with dual planes. Some claim success with the center divider cut out. Some claim you need single plane intake period. I would thoroughly research this yourself but go into it knowing you might need to pull the trigger on an intake.
The symptoms apparently is a off idle to mid RPM stumble that can't be tuned out. The forums are littered with folks arguing point either way.
https://www.dailymotion.com/video/x3klp5c
Old Dec 26, 2020 | 06:17 PM
Vette5311's Avatar
Vette5311
Thanks. I can see that. A single plane would almost have to have more equal distribution because of the closer to equal length of the runners! Now one has to wonder about the effect of LSA on the camshaft because of reversion also. Just thinking out loud.
Old Dec 26, 2020 | 09:27 PM
mitch.1972vette's Avatar
mitch.1972vette
I'm going to use a dual plan on my small block...434... I honestly think it comes down - rock bottom - to what you are trying to do. I love horsepower, but if you have to wind it up to 8 or 9k --- that isn't in my comfort zone. For me, I love torque -- that pull your eye sockets out of the back of your head kinda torque....That is fun power to me......If you desire a high revving car that lives in the 7k to 10k range...A single plane would likely be a great choice. I honestly believe that when it comes to fuel injection and carburation there are still simple rules that still apply. What do you want to do with your little car?
Old Dec 26, 2020 | 10:40 PM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
Shortly after running my "77 EFI conversion" thread, I also had a thread going on the intake manifold side of things.
On my car I'm running a Performer RPM manifold. higher rise than a stock manifold to be sure. I had no issues whatsoever. However, I did cut out the center divider about 6 weeks after the initial install. can't tell any difference.
from all the reading I've done on the topic. those with manifold tuning issues generally have a standard low rise manifold.
Old Dec 27, 2020 | 04:53 PM
Rescue Rogers
The dual planes have been known to have various issues with a shallow air plenum on the one side. Cutting the center plenum divider out or using spacers seems to be a good resolution for some. I used the tarantula and had zero issues by using a big spacer. My big block build is getting a single plane because Im trying to limit the torque. The cam-intake-head combo im looking at is about 520Ft/lbs 510hp. Im trying to preserve my 5 speed until I can afford the new TKX. Hopefully we can get a group buy
Old Dec 27, 2020 | 09:43 PM
mitch.1972vette
Yes sir...I understand that is an absolute must.. (cutting the divider or center plenum divider).....The combination you have chosen sounds like a whole lot of fun!!! I look forward to following your thread..
