Dyno results, before and after!
At the same speed or acceleration rate, the drivetrain will eat up the same absolute power (as I said before, I don't say "percentage") regardless of the engine maximum capability. I believe we have been in agreement there. (Correct me if I am mistaken.)
Just so we can be on the same page, when you say "get your tires spinning", are you taking into account time or acceleration rate to that particular tire speed?
It has been long accepted by the industry that a 15-20% HP loss is normal from an engine dyno to a chassis dyno. Most use a 15% figure as their baseline. This number has come from hundreds and hundreds of vehicles that have had their engines dynoed and then they were put on a chassis dyno to do final tuning. The tuning on the engine dyno will not be the same as when the engine is in the car with full exhaust, air cleaners, under hood hot air etc... The op is correct to assume about a 20% HP loss to what he would see on an engine dyno. We usually used the 15% figure, but it is impossible to know exactly what it is.
When an engine is on a dyno, there are no parasitic engine loses, there are no power steering pumps, AC compressors, alternators, engine fans, and even the water pump is normally run with an electric motor, There is no exhaust and no mufflers. You also do not run an air cleaner or filter, but a huge velocity stack that is open. The PS, AC, ALT, fan, and water pump take quite a bit of HP to run. When you are on a chassis dyno all that stuff is connected to the engine and is creating parasitic loses. Then you have your air cleaner, air filter and hot under hood air. On top of that you have the loses from the transmission, and if you have an auto transmission you have loses from the slippage of the converter. You have your mufflers and exhaust, your differential, and your bearings, brakes and everything else that slowly adds up. You could have a car that from an engine dyno number to a chassis dyno numbers could be less that 15% loss, but it is usually an outlier. If you have no PS, AC, an electric water pump, electric fans, an underdriven alternator, a manual transmission, a small differential, drum brakes etc... you will probably be under that 15% but normally 15-20% is about right. Auto trans and lots of engine driven accessories, full exhaust you will be closer to 20% losses, manual trans with little engine driven accessories closer to 15%.
At the end of the day dynos are tuning tools, they are not there to tell you exactly how much power your engine has, but to help you get the most out of your present combination.
By the 1980's all of that changed. The convertors got better, the cars got fuel injection, the computers got better, and a second O2 sensor appeared. The convertors even went to low restriction honeycomb at some point. The convertors were no longer a big liability, and performance came back!
If you put a 1985 convertor on a 75 engine I would bet it would gain an easy 30-40+HP.
Jebby
At least this is a bit more enticing than reviving 15 year old threads on the topic which is not encouraged here and thus would not promote this knowledge to be "rehashed" at all unless a new discussion comes up.
At high vehicle speeds, the aero drag is sufficiently high to where the acceleration rate is small, reducing the amount of horsepower/energy being added to the "flywheels". At top/terminal speed, the drivetrain losses are purely frictional, as there's no additional horsepower/energy being stored into the "flywheels".
I do agree with your concluding sentence.
