steering column too short?
Old Dec 31, 2020 | 03:05 PM
teamo's Avatar
teamo
Default steering column too short?
Hi All,
I sent out my T/T column for rebuilding. I got it back and attempted to reinstall it but it is too short. The rebuild looks good and I am not too sure that the problem wasn't already there when I removed it. When I took it out of the car it was not bolted at the firewall to the transmission lockout bracket. The lockout cable bracket was just floating and the column was only held in place with the upper bolts to the under dash bracket. So as it stands with the column bolted to the bracket under the dash the firewall floor bracket is off of the floor about 1.5 to 2.0 inches. The connection at the steering coupler is also short about that much. The steering shaft extends out of the bottom of the lower bearing 5". Can the column jacket be too short perhaps a different GM vehicle? What is my solution here? Is the outer column jacket adjustable? Do I need to cut the firewall bracket off of the column and have it rewelded lower on the column. As you can also see the transmission lockout arm needs to come out about 2 inches to be on the outside of the firewall. The lockout arm in the picture is bent out slightly so that I could get it through the firewall cutout and will be bent back straight once the column is bolted in.
column bolted to the upper bracket slid all the way forward.
column to bracket bolts
flange has approximately a 1.5 to 2 inch gap to the firewall floor.
gap is about 2" with the flange and coupler installed (not shown)
column to bracket forward adjustment
gap at bottom of firewall flange/bracket
Old Dec 31, 2020 | 04:05 PM
80VETENG's Avatar
80VETENG
deleted
Old Dec 31, 2020 | 04:41 PM
Mooser's Avatar
Mooser
IIRC, you should install the column to the floor and put the bolts in place down there and then you use the wedge shape intermediate bracket, those bolts you show as well as the ones that go to the column itself, to adjustment to get the height to fit the drivers dash pad. and the slots sideways are on the top bracket that went to the firewall
M
Old Dec 31, 2020 | 06:42 PM
corvgreg's Avatar
corvgreg
Emerging Vendor
The column may be collapsed. The mast, shift tube, and main shaft all can collapse in(is for safety purposes).
[QUOTE=teamo;1602753334]Hi All,
__________________
Greg
Old Dec 31, 2020 | 06:48 PM
Mooser's Avatar
Mooser
I didn't realize (read) it was that short...
The steering rod from the lower bearing sb about 4-5/8" (72 T/T)
M
Old Dec 31, 2020 | 06:54 PM
Mooser's Avatar
Mooser
Jim Shea's papers are here
http://jimshea.corvettefaq.com/?cat=5
Not sure if there will be a length of the body in there somewhere. Found a reference to a 81-82 but that's not helping you
M
Old Dec 31, 2020 | 08:53 PM
bobby70's Avatar
bobby70
can I ask where you sent the column to because that same thing happen to me
Old Jan 1, 2021 | 12:44 AM
corvgreg's Avatar
corvgreg
Emerging Vendor
The 4 5/8 shaft projection is fine. But if the column itself is collapsed it will then be too short afterwards.
There is a plastic collar with small ball bearings in between the upper and lower pieces. I can give you measurements.
Old Jan 1, 2021 | 12:47 PM
teamo's Avatar
teamo
I think the column has collapsed, probably due to rough handling while shipping. I can get the shaft to extend out to 5" but the column jacket is what will need to be adjusted to bring the flange tight to the floor so that I can bolt it in. I did find evidence of previous damage to the firewall that was repaired at some point in the past. I was thinking that maybe they grafted in the new fiberglass at the firewall and this had extended the firewall out 2" from stock. Looking at it now I think that may not be the case because I removed and restored the brake pedal and column brackets, Reinstalling the brake pedal bracket was a tight fit to the firewall so it is likely that the firewall is in the correct location.
Old Jan 2, 2021 | 01:46 PM
80VETENG's Avatar
80VETENG
Check the Bracket (with the 4 slotted holes) is all the way forward on the 2 bolts that attach it to the Brake Pedal bracket, they are slotted. Also the 2 bolt holes on the steering column are slotted and you may have some additional adjustment there.
Old Jan 2, 2021 | 04:03 PM
3X2's Avatar
3X2
How was the column shipped? They are very easy to collapse if dropped or banged on the shaft end. If the column fit before you removed it, then something happened between removal and receiving it back. The last column I bought came in a wooden crate with internal cutouts to support it.
Old Jan 2, 2021 | 05:34 PM
teamo's Avatar
teamo
I have the bracket all the way forward. I'll double check the slots that mount to the brake pedal support. The column was pretty well packed with bubble wrap and a section of pvc pipe slid over the steering shaft at the floor end.
Old Jan 2, 2021 | 07:18 PM
corvgreg's Avatar
corvgreg
Emerging Vendor
Heres the measurement from back of front mounting plate to the rear firewall plate.
Old Jan 3, 2021 | 07:55 PM
teamo's Avatar
teamo
Thank you for the detailed measurement. I'll go out there tomorrow and check what I have.
To steering column too short?
