C3 Stalls
Old Jan 3, 2021 | 09:22 PM
rreggio's Avatar
rreggio
2nd Gear
Default C3 Stalls
I recently picked up a 1979 coup. It started great and ran great until I put in some premium fuel. The first time I drove it after putting in the premium fuel it started just fine, but when I pressed the accelerator the engine sputtered and died. This happed several times. Could this be the fuel or something with the fuel system?
Old Jan 3, 2021 | 09:52 PM
MelWff's Avatar
MelWff
You could have gotten a tank of bad gas.
Is it low enough to refill?
Old Jan 3, 2021 | 09:55 PM
rreggio's Avatar
rreggio
2nd Gear
It a full tank, so if it’s the gas I will have to get it removed. Thanks
Old Jan 3, 2021 | 10:31 PM
forman's Avatar
forman
If you take a strong flash light you should be able to see the bottom of the tank through the fuel
Old Jan 4, 2021 | 10:59 AM
interpon's Avatar
interpon
verify fuel delivery to carb.. check filter..
To C3 Stalls
