79 carburetor choke pull off question
79 L82 manual orginal carb ~35000 miles..
Eventual plan is to get carburetor off to Lars (but i can't stop driving it)..
As far as i know no issues with cold startup until last week.. temps drop below freezing, (garage 40-50f ish..) usually 2 pumps then fast idle (longer now with out heat riser) drop while warming and all is well. Warm and any restart within hours OK..even out in freezing temps..high idle right away.
Now starts after 2 pumps (COLD ambient) ..but not high idle.. stumbling smoking (blue black?) barely catch it pump gas rev it up clears out.. then finally high idle..all is well..
So i have a read a LOT of threads.. and a some of Lars forensic rebuilds..
- tightened visible screws and top bolts..and mount bolts. (Gentle snug) all tightened slightly..
- went to choke pull off.. the vacuum line was very original and loose wet.. and kinked.. it is like an S shape from carb to pull off.
- sucked on the end of a good hose on vacuum pull off and it moves but leaks vacuum.. cannot get it to retract fully (out of breath from it leaking).. distributor vacuum holds as a comparison.
questions please
- is that a special 5/32 vacuum hose like an s shape or just replace with a straight hose?
- should the pull off hold vacuum? if so any thoughts on part # to replace?
again i am speculatin this is the issue.. carb has gas and can see it squirt at cold so bowls are full.. its like it is flooded at very cold start..
thank you!!!
Popular Reply
The choke pulloff, in addition to cracking the choke open for proper cold-start, also acts as a "damper" for the secondary airvalve. If the secondary airvalve is allowed to "pop open" too quickly, it will cause a secondary tip-in bog/stumble due to a lean condition on the secondary side. By controlling the airvalve opening rate, there is a secondary fuel shot that is induced, duplicating the function of an accelerator pump. It is important that this occur in order for the carb to produce a smooth secondary transition.
Unfortunately, the current aftermarket replacement choke pulloffs do not have the correct bleed delay restriction in them, and they will allow instant opening of the secondary airvalve, with associated stumble and bog problems. So the new pulloffs have to be reworked to install a correctly calibrated air bleed restriction. If you have replaced your pulloff and now have a secondary tip-in problem, you need to modify your pulloff. I've seen many of the replacement pulloffs for the 1968-1970 carbs with the same problem.
Lars
It is easier for me to attach linkage and hose to assembly. Then move it into the correct position and install the mounting screws last.
Lars
Lars
Question:
The Corvette parts and illustration catalog calls out 17050759 for 76-79 L48 M38.
It also calls out 17053201 for the 77 M40 and 75-79 High Performance.
Physically they look the same, is the difference just the way there are calibrated (Bleed Off Delay Time)?
Thanks Lars!
... Unfortunately, the current aftermarket replacement choke pulloffs do not have the correct bleed delay restriction in them, and they will allow instant opening of the secondary airvalve, with associated stumble and bog problems. So the new pulloffs have to be reworked to install a correctly calibrated air bleed restriction. If you have replaced your pulloff and now have a secondary tip-in problem, you need to modify your pulloff. I've seen many of the replacement pulloffs for the 1968-1970 carbs with the same problem.
Lars
My car is no where near stock, and still figuring out just what I have, while getting ready to drive and enjoy her (at paint&body now, not driveable yet). And while I can't swear that I DO have any tip in problem, given all the rest of this issues this car has, it won't surprise me if I do!
Thanks,
Paul
Lars
Lars
One more question if I may: the way I was taught to set the mixture and idle screws was to: in small increments, bring the mixture screws (left and right) out until the max vacuum was achieved, and bring down idle speed incrementally if needed to keep it from going too high, but around 1200-1500 or so was acceptable. Then once the max vacuum is done, bring the idle speed down to the approx 750-ish, and button it up.
Does this sound right?
Paul
!! cant wait..
