Will a ‘80 radio into ‘73
Old Jan 8, 2021 | 08:09 PM
RobMc1963$'s Avatar
RobMc1963$
Default Will a ‘80 radio fit into ‘73
Has anyone tried putting a 1980 Vette radio in a 1973 Vette? It what I can get at the moment without costing a arm and leg.
Old Jan 8, 2021 | 11:16 PM
SteveG75's Avatar
SteveG75
Completely different form factor. You would need to cut up the center dash.
Old Jan 9, 2021 | 04:44 AM
C3Highway's Avatar
C3Highway
Steve is correct. For the 1977-1982 Corvette, Chevrolet designed a new console and center stack that would accommodate the entire range of GM's Delco radios due to increased depth.
I believe the radios installed in the C3 prior to '77 were particular to the Corvette due to restricted space.
Old Jan 9, 2021 | 09:38 AM
RobMc1963$'s Avatar
RobMc1963$
Thank you
Old Jan 9, 2021 | 02:04 PM
73sbvert's Avatar
73sbvert
Crackin' on...
St. Jude Donor '09
I have a '73 stock radio and 1 channel amp (powered single speaker under dash) I could sell, $75 plus actual S&H.
They worked when they were pulled according to PO. Have been wrapped in storage ever since.
Paul
Old Jan 10, 2021 | 09:24 AM
Elcransonator's Avatar
Elcransonator
I'm curious too, as one of the POs of my '73 removed the original radio/put in one that says "Corvette" across the top. It doesn't work, so I'd like to find an original Delco AM/FM stereo with the silver bar that slides left and right (to go from AM to FM). Any ideas other than Ebay?
Old Jan 10, 2021 | 11:45 AM
SteveG75's Avatar
SteveG75
Ecklers sells a modern radio that looks just like the original. But, it support BT and is stereo. Not cheap though.
I was considering it but would it have replace the gauge bezel since I cut it many years ago to install a DIN stereo.
Old Jan 10, 2021 | 12:28 PM
Blue73Shark's Avatar
Blue73Shark
Check out the C3 Parts for Sale/Wanted section of this Forum. Numerous radios that would fit a 1973 have been listed in the past year. Here is a 73 radio that sold in March 2020:
https://www.corvetteforum.com/forums...reo-radio.html
Good luck!
Fran
Old Jan 10, 2021 | 02:18 PM
Elcransonator
Thanks Fran!
Old Jan 10, 2021 | 02:26 PM
interpon's Avatar
interpon
Good luck!
Fran
then (no matter where you get it) send it here..clean fixed and aux cable added...even diagnosed a power surge that blew out my stereo...and correctly noted no way i had a 10 amp fise in my fuse board..he was correct. ...30 someone put in..working perfect still
https://www.corvetteforum.com/forums...questions.html
Old Jan 11, 2021 | 09:17 AM
Elcransonator
Thanks Interpon! I might drop that guy an email before I start trolling on Ebay to make sure he's still in action and to see if he might have one laying around.
Old Jan 11, 2021 | 11:57 AM
RobMc1963$'s Avatar
RobMc1963$
Thank you but I think I am going to go with a modern with blue tooth since the 80's doesn't work. Thanks.
Old Jan 11, 2021 | 01:11 PM
SteveG75's Avatar
SteveG75
Here are two options:
https://www.zip-corvette.com/68-76-a...oth-radio.html
https://www.zip-corvette.com/72-76-a...oth-radio.html
Old Jan 11, 2021 | 01:17 PM
interpon's Avatar
interpon
mine is bluetooth OEM.. he adds an AUX cable..you can feed for BT...just an option.. or plug right into your phone..(with AUX to phone adapter..).. mine comes into ashtray with grommet..
Old Jan 12, 2021 | 10:00 AM
RobMc1963$'s Avatar
RobMc1963$
Nice. That is a great option. Thanks.
To Will a ‘80 radio into ‘73
