1980 Rear end clunk!
Old Jan 16, 2021 | 11:24 AM
GS CUL8R's Avatar
GS CUL8R
Default 1980 Rear end clunk!
Hey Everyone,
Working away on this 1980 project and now at the rear end. Its got a good clunk when putting it into gear. What am I into on pulling this apart and any guesses on what it is?
Thanx
Old Jan 16, 2021 | 11:28 AM
MelWff's Avatar
MelWff
look at the rubber bushings attaching the front differential bracket to the frame.
Old Jan 16, 2021 | 11:41 AM
GS CUL8R's Avatar
GS CUL8R
Changed it as well as all the U joints. Should have noted that!
Old Jan 16, 2021 | 04:03 PM
Mrvettenick's Avatar
Mrvettenick
Assuming your idle speed is at spec. You might have too much backlash between the ring and pinion, How many miles on this rear? Trying to readjust backlash on a used ring and pinion is dicey. You might develop a whine if you bring it back to spec. Also check the trans mount. Sometimes they wear/break.
To 1980 Rear end clunk!
