Power steering pump
Old Jan 20, 2021 | 05:08 PM
Larsonyst's Avatar
Larsonyst
5th Gear
Default Power steering pump
Will a 1979 power steering pump work with a 1988 rack and pinion
Old Jan 20, 2021 | 10:16 PM
MelWff's Avatar
MelWff
Rack and pinion uses higher pressure pumps , 500 psi more.
You were told in the C4 forum you need a C4 pump for a C4 suspension used in a 63 Ford truck.
https://www.corvetteforum.com/forums/c4-general-discussion/4486495-1988-power-steering-and-rack.html#post1602820331
Old Jan 20, 2021 | 11:18 PM
Larsonyst's Avatar
Larsonyst
5th Gear
Default power steering pump psi
how much pressure do the c3 pumps put out
Old Jan 23, 2021 | 07:33 PM
69427's Avatar
69427
From: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
I ran the stock '69 Saginaw pump with the R&P on the C4 suspension under my car for several years. Operated just fine. The only mod to my pump was a different (larger) orifice fitting at the pump outlet that I put in decades ago when I still had the stock C3 suspension. The stock orifice was so damn small that the fluid flow was overly restricted, making it damn hard to turn the steering wheel quickly during autocrossing. A very helpful competitor (Bill, RIP) gave me the solution to the slow steering response problem.
I eventually replaced the stock heavy Saginaw pump with a later model aluminum Type II pump for weight reduction reasons.
Old Jan 24, 2021 | 02:05 AM
Larsonyst's Avatar
Larsonyst
5th Gear
thank you for your input do you have a part number for that fitting/ orfice thanks again for your help
To Power steering pump
