1980 tach issues
Old Jan 26, 2021 | 03:24 PM
GS CUL8R's Avatar
GS CUL8R
Default 1980 tach issues
Ok so I have an 80 project car and am having issues with the tach. Changed the board on the back of the tach and still the tach is not working. Seems to be sending power but when you start the car the tach will go up but wont come back down. Also wont register anything at idle?? Thoughts??
Tahnx
Old Jan 29, 2021 | 03:44 PM
MelWff's Avatar
MelWff
have you read through this document?
willcoxcorvette.com corvette-tachometer-testing-removal-board-installation
Old Jan 30, 2021 | 12:34 PM
GS CUL8R's Avatar
GS CUL8R
Originally Posted by MelWff
Thanx for the link, yes I saw this and tested it and all check out except tach wont work! Really scratching my head now...
Old Jan 30, 2021 | 07:25 PM
'75's Avatar
'75
I had an issue on a 78 tach that was intermittent. It turned out the clips that the tack board studs slip into were loose and not making good contact. I "adjusted" them for more tension, problem solved.
Old Feb 1, 2021 | 09:29 AM
GS CUL8R's Avatar
GS CUL8R
Will give that a try....so far nothing seems to be working!
To 1980 tach issues
