C3 brakes, UGH!
Do Not Insert Screwdriver More Than 1 & 3/8" Or You Will Void the Warranty.
https://www.corvetteforum.com/forums...-cylinder.html
Then once you have all the air from the MC, use pressure applied at the MC to bleed the calipers.
1. Push each caliper piston in using the brake pads as support and block with vise grip or something to keep the caliper piston in position.
2. apply pressure at the MC
3. open the caliper bleeder to bleed.
4. once no air bleeds, remove the vise grip support at the pads to allow the caliper pistons to return.
5. remove air pressure at the MC.
Here is what I use to apply air pressure at the MC. ~ 20 PSI.
Your local NAPA should have "ready-made" steel brake lines about a foot long with fittings. Note that the front MC brakeline port and rear port are different diameters and thread pitch. Take that info with you to the store. Each test line will need to be blocked off on the other end. Smash, squeeze, pinch or install a brass cap.
Remove front & rear brakelines one at a time from MC. Quickly attach your test lines and bend upward to clear inner fender, etc. Now, you should be able to stand on the brake pedal. If that pedal moves, the piston seals are toast (post #1). If the pedal doesn't move, look elsewhere.
Never use a plug or a bolt in the MC line port. There is a flare inside, that is part of the castings that can be damaged.
You will need to to bleed the entire system again after testing the MC. You have introduced a bubble at the MC.
A lot of air in the system would give you a spongy pedal.
Pads good, not glazed?
Combination block/valve not offset?
Good fluid flow from all the calipers?
Did you have this condition before you changed the mc?
Pedal has always been a bit spongy.
I have tried 3 different sets of pads.
Fluid flows well to the calipers when bleeding them.
My original MC was a 1.25 diameter, the correct diameter for a manual is 1.0 inch, is why I changed it... REALLY bad before I changed it.
The rear calipers are almost horizontal. I think this is an issue when bleeding them, especially the outside half of the caliper. These calipers have 3 bleeder ports, 2 on the outside, one on the inside. I think they are there for a reason. The outside half of the caliper being horizontal must be difficult to extract all of the air. I think bleeding that side by itself helps get all the air out of the system. I started by lowering the rear of the car to get a slight angle on the caliper. I used my pressure bleeder on the lower port, then opened the upper port on that side during bleeding. I kept the cover on the MC to keep the pressure isolated to the one side of the caliper. I did get a few bubbles.
I really don't think compressing the MC, all the way, during bench bleeding will hurt the seals. There really isn't anything in the cylinder that will scratch the seals on a new MC. Also during normal braking, I think the plunger is compressed most of the way, anyway.
Soooooo, after all this, my brakes are a bit better, but still just OK.
If you have a hard pedal, but poor braking, you need different pads, or something else is wrong. If you don't have a hard pedal, try pressure bleeding again, while tapping the calipers and junctions with a wrench. You still have air somewhere.
What happens is the seals get "rolled-over" from snagging on something in the bore. This renders the seals useless. And voids the warranty. Your local parts store will never know the difference if you return the defective MC. But Lonestar knows.
Keep in mind that the distance you're shoving in the piston on your work bench is greater than the distance the brake pedal would travel. The pedal has a stop.
Your arm & screwdriver does not have a stop.
You state: fluid flows well to the calipers. That does not confirm the MC is building pressure.
It does not matter how many pads / rotors or whatever you put on the car, if the master is not building pressure you are not stopping on a dime. Your MC was bench bleed incorrectly. You can deny the MC is at fault here all you want. But it was never tested. I am not trying to be harsh here, but you have to go back to the begining and verify what's working, what is not.
You have to test the MC solo, all by itself, to see if its even doing its job. Outlined in post 9.
And because you went from a PB master to a manual master, was the pedal rod / MC gap ever checked?
Then proceed with your pads, etc.
I know brakes are frustrating but you will fix it right.
