I have a l46 rebuilt @ 20k miles ago but sitting for many years. It looks like when they rebuilt it they went with flat top pistons 30 over and switched to 202 angle plug heads ( I have originals but they would need rebuilt ) I'm thinking about switching to a bigger cam while its out. I have 373 gears with M21 4sp. any suggestions on cam profile? Also plan on going to Holley sniper fi.
Every cam company has a 1-800 number with a tech guy that will gladly take all your information and come up with a perfect match cam.
That's what you want right?
They will need additional info than what you provided.
Thanks for the help. I just felt there must be a better choice than the stock cam since that cam had to work in corvettes running automatics and or higher geared rear ends. I don't want to change my heads so I'm not looking for anything crazy just hoping to get 30 or 40 more HP out of my 350/350 small block.
You indicated a desire for a 'bigger cam' but you also stated that a previous owner replaced the original domed pistons with flat top pistons. You also indicate the heads have been replaced. I agree with previous posts suggesting technical assistance from several cam vendors but before going this route you need to determine your current compression ratio. The original piston/head combination created an 11:1 ratio. The stock cam was designed for that figure. Unless the head was decked, removing the piston dome cut that ratio down. I believe the original heads were 64cc combustion chambers. (Don't hold me to that.) If you can find the combustion chamber size for the current heads, great. If not, you need to measure it. Once you have this data, my guess is you'll discover the existing cam (assuming it's the original) is actually to 'big' for the current combination. I'm suggestion basically that your heads/piston/cam combination produces a dynamic compression ratio that's too low and your '350' horsepower and associated torque have been severely compromised. If I'm right, you can probably get much of the original performance back with a cam of less duration, but whether you or a vendor figure that out - you'll need the CR data I just discussed.
The current heads are 202 angle plug 64cc chambers.I'll also be running a performer manifold with fuel injection. It is a side pipe car and I will run 3/4 headers to the side pipes. From everything I've researched my compression should be @ 10 to 1. I'm pretty sure that even though my compression is a point lower with the improved exhaust flow and fuel delivery I should be able to run a slightly bigger cam and gain some performance. In the future if I go to a Tremec 5sd I'll also change to 411 gears.
The angle plug heads were very good in thier day. Modern aluminum aftermarket heads are better. I think the right cam would give you back the power lost by the flat top pistons quite easily.
I've got the same car, basically, but I still have 11:1 compression. I put some 200CC heads on, performer intake, Sniper EFI, and I put a Jones Cam in. He did a custom grind for me with a reverse duration pattern due to how high altitude I live at. I would suggest a single pattern for you, but here are my specs. It runs really well, gobs of power. 224/220 @.050"
.330"/.310" Lobe Lift
.495"/.465" Valve Lift
110 LSA
106 ICL
110 LSA
106 ICL
What kind of heads are you running? The 202 heads still look like new would I need to run different valve springs with your cam?
They're Flotek heads - don't buy from them. The heads are fine for the money, but I should have gone with a better company.
Who knows how your heads are set up. The valve lift isn't a lot on this cam, so probably, but if it was me, I'd probably start from scratch. Valve springs aren't a lot of money.
