1971 2"-2.5" exhaust system
Old Jan 29, 2021 | 08:00 PM
jrs71's Avatar
jrs71
Default 1971 2"-2.5" exhaust system
I currently have the stock 2" on my 350/270hp. Would like to replace with the 2" >2.5". A couple sites list it as an LT1 system. Has anyone already done this? Was ther any noticable differences? What else is needed besides the pipes and mufflers?
Old Jan 29, 2021 | 08:18 PM
PJO's Avatar
PJO
Veteran: Marine Corps
The center pipe hanger under the trans. would need to be for 2 1/2" pipe.
Old Jan 29, 2021 | 10:04 PM
carriljc's Avatar
carriljc
On my 68 I installed 2.5" ramhorns, 64-65 2.5" downpipes, and then the rest of the 2.5" system all the way back including the mufflers.
Give me a few and I'll find the link.
I bought from several different places for the best prices with parts and shipping.
Be right back.
Old Jan 29, 2021 | 10:09 PM
carriljc's Avatar
carriljc
Here you can see.
You need the center support and 2.5" clamps. See below and there's lots of information and part numbers and whatnot:
https://www.corvetteforum.com/forums...post1598185200
Old Jan 29, 2021 | 10:16 PM
BLUE1972's Avatar
BLUE1972
I've been toying with the idea on my 71. Was just wondering if you felt or saw any increase in performance.
I figure the exhaust will need replacement this summer.
I was looking at speedway for the ram horns.
Did anyone look at the walker exhaust gasket / donut , looks flat on the bottom and tapered on the other side. for the drivers side.
Walker Exhaust 31398 Walker Exhaust Flange Gaskets | Summit Racing
Old Jan 30, 2021 | 01:08 PM
leigh1322's Avatar
leigh1322
Old Pro Solo Guy
Yes the stock LT1s still used the standard 2" opening rams horn manifolds. So the original header pipes were 2" opening and within 6 inches or so grew into a 2.5" pipe. I am not sure if there was a weld there or if the pipe was just re-sized. There were some 2.5" rams horns made sometime in the mid 60s on some of the C2 engines. IIRC those are being reproduced today. Hopefully the C2 header pipe would work for you. 64-65 maybe? 327/365 or 327/375 models?
Old Jan 30, 2021 | 05:54 PM
carriljc's Avatar
carriljc
You can use the 64-65 2.5" downpipe with 2.5" ramhorns. see my comment above and the link where I did it.
Old Jan 30, 2021 | 10:25 PM
7T1vette's Avatar
7T1vette
If you install 2.5" pipes on a stock 270hp SBC, you will notice ZERO difference. That engine doesn't need 2.5" pipes to breathe; its "lungs" are too small. Save your money.
Now, if you decide to install much better heads and cam, THEN you should up the exhaust size.
Old Jan 31, 2021 | 08:09 PM
Dino_'72's Avatar
Dino_'72
I recently installed a 2.5” Corvette Central complete exhaust system with Magnaflow mufflers on ram horns. Went from 2” system. I initially had clearance issues where the pipe goes through frame crossmember. Had to get a new tranny mount. My factory original mount was in there and had compressed over time causing the clearance issue. Just a heads up. I can’t comment on power definitively cause I changed heads and cam as well. It is much louder than I thought it would be with the Magnaflows and 2 1/2” pipes.
Old Jan 31, 2021 | 09:58 PM
BLUE1972's Avatar
BLUE1972
64 - 65 327 / 365 had 2.5" - factory , same frame so they fit.
Just wondering if a 400 hp engine will benefit enough to make it worth wile
Old Jan 31, 2021 | 11:29 PM
7T1vette's Avatar
7T1vette
400hp engine requires 2.5" exhaust. Some would say that 3" exhaust would be better. But, no stock C3 was ever configured with a 3" exhaust system.
Old Feb 1, 2021 | 08:18 AM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
Originally Posted by carriljc
Here you can see.
Unless you are going long tube header...this is what I would do......and it is most definately worth power on the 350.......the 2" Rams Horn is a cork.....the 2.5" is much better but still not optimal.
On the factory stuff....the 2" outlet was small enough, then GM bent the front pipes with a heavy kink in them......terrible design. And as far as no gain? Take a look at any new 2.4/2.5l 4 cylinder nowadays......tell me what size the outlet is......part of the reason the 270hp made 270hp is the damn manifolds.....you can put long tube headers on this engine and gain 25hp........the 2.5" outlet is worth 15 by itself.....
Jebby
Old Feb 2, 2021 | 02:14 AM
Pale Roader's Avatar
Pale Roader
Jebby
Agreed.
2" pipe, even mandrel bent, is enough to flow a stock 200HP V6. Maybe. 2.5" mandrel should be considered MINIMUM. Why are we even still having this conversation? Exhaust technology has come a LONG way in 40-50 years.
Old Feb 2, 2021 | 11:46 AM
Taijutsu's Avatar
Taijutsu
My engine pulled 280 rwhp
and 315 rwtq
Through the 2" RH manifolds and 2.25 ex pipes.
I have the 2.5 RH and 2.5 ex pipes.
I would like to make 300 rwhp!
Old Feb 2, 2021 | 05:29 PM
nwav8tor's Avatar
nwav8tor
Old Fart Pilot
After reading all this and considering WAY too many options, I just ordered forum vendor Corvette Central's 323710-MAG exhaust system for my '71 SB. It's aluminized steel, 2" @ manifold necking right up to 2-1/2" for the remainder of the system. I went with the seperate pipe pieces which then mate to Magnaflow mufflers rather than the welded system. My rationale was since this is what the LT-1 had, it should be better than the all 2" system that was originally on my car. My mildly upgraded rebuilt 350 should breath better and this still allows for future upgrades such as 2.5" ram horns and '65 2.5" down pipes connecting to the remainder of the CC 2.5" system. Who knows, might even get headers one future day, but for now I just wanted to get the parts ready for easily getting her back on the road. $427 (incldg 10% discount) + $60 flat rate shipping.
Old Feb 3, 2021 | 02:54 AM
Pale Roader
You do realize that a system is only as big as its smallest section, right? Even a full 2 1/2" press-bent system is often less than 2" in some ov the bend areas. The engine/exhaust doesn't care how big the tips or the undercar pipes are, only the most restrictive points.
I'd upgrade to those 2.5" manifolds and headpipes before you even put it on. That Corvette company should not even be making those 2" drinking straws.
Old Feb 4, 2021 | 01:21 AM
nwav8tor's Avatar
nwav8tor
Old Fart Pilot
So, I'm no expert and I don't know what your qualifications are, but I have to assume that the Chevrolet designers & engineers that worked on the LT-1 models had a reason for using the 2.5" pipes after the 2" manifold and I bet it wasn't to impede performance. Using your comment about the smallest section being the most restrictive, that may be somewhat true, but I still bet you that a 2.5" system with bends taking it down to a smaller diameter in places will flow better than a 2" syatem with bends reducing that system down even further.
As for "that corvette company should not even be making those 2" drinking straws" comment, have you ever heard of people trying to keep their cars as original as possible? Not everbody is solely concerned about maximizing performance...
Paul
As for
To 1971 2"-2.5" exhaust system
Old Feb 4, 2021 | 07:16 AM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
Paul
As for
I understand the original and bolt on aspect of staying at 2”, but the reason GM went with 2” after 1965 on all small blocks was a simple cost reason....no other reason.
2.5” outlet manifold on an LT-1 are worth 15-20 upstairs and a long tube header is worth 30 or better....this is through full exhaust at the tire....
It also just runs crisper with the exhaust uncorked....the LT-1 cam has a lot of overlap....the more overlap, the more crucial good exhaust is....
The 66’ in the Avatar has 2.5’s on it because it moved a lot of air.....it was worth it.
Jebby
Old Feb 4, 2021 | 10:08 PM
Pale Roader
They also had a reason for using complete garbage bias-ply tires and points ignition. Thats what was 'hot' and available (for reasonable cost) at the time. Doesn't mean its not useless garbage now. They didn't know any better, and as Jebby said, were likely trying to save money. How many (literal) miles ov that pipe did Chevrolet have to buy? 2" is a decent amount cheaper than 2.5". Besides... like the hot 427 cars with those horrible manifolds... they expected anyone wanting real performance to toss them for headers at the earliest convenience.
Old Nov 26, 2023 | 12:47 PM
jm1gic's Avatar
jm1gic
do you have the link to the ones that you used?
