Battery Tender
Old Jan 30, 2021 | 09:16 AM
dmpdmp's Avatar
dmpdmp
Default Battery Tender
Where can you connect a battery tender up under the hood instead of at the battery compartment. Looking to run a wired hidden connection to the front grille/bumper area. Thanks
Old Jan 30, 2021 | 09:24 AM
drwet's Avatar
drwet
You could connect the positive terminal to the large positive terminal at the starter solenoid and the negative to any good chassis ground.
Old Jan 30, 2021 | 09:26 AM
dmpdmp's Avatar
dmpdmp
Thanks ill check that out
Old Jan 30, 2021 | 09:36 AM
bruiser's Avatar
bruiser
St. Jude Donor '15
I connect it to the alternator
Old Jan 30, 2021 | 11:33 AM
MelWff's Avatar
MelWff
I connect mine to horn relay
Old Jan 30, 2021 | 11:52 AM
resdoggie's Avatar
resdoggie
Had a 1976 L-82, 4-sp
Royal Canadian Navy
I connect mine in the battery compartment and run the 120V cord out through the bottom of the door. How does one run a hidden connection? You need to plug the visible 120V cord into the wall outlet.
Old Jan 30, 2021 | 02:45 PM
Redvette2's Avatar
Redvette2
On mine I just disconnect the provided DC plug and leave the Tender and AC part plugged into the receptacle on the wall.
Old Jan 30, 2021 | 02:56 PM
drwet's Avatar
drwet
The alternator would work just as well. The battery is connected directly to the starter and the starter is connected directly to the alternator. There are probably a bunch of other places you could connect it if you were to consult a wiring diagram and see what else is connected directly to the battery. I suppose it you just checked for any terminal that has power when the key is turned off it would work just as well.
Old Jan 30, 2021 | 03:16 PM
barkingrats's Avatar
barkingrats
1967 Pedal Car Champion
I use a battery disconnect during extended down times just to reduce the risk of electrical fire. I'd connect the tender directly to the battery and just live with the inconvenience -- just something to think about.
Old Jan 30, 2021 | 11:12 PM
7t9l82's Avatar
7t9l82
I have it wired to the battery and run it out the door a d just take the tender out
To Battery Tender
