O2 Sensor Plug location
Old Jan 31, 2021 | 08:51 PM
opichi34's Avatar
opichi34
5th Gear
Default O2 Sensor Plug location
Hey guys, I'm working on a 75 C3, L82. I found the O2 sensor on the driverside exhaust manifold, but the wire is cut. Does anyone have a picture of where the plug should be?
The car has been running fine with it cut, and starts right up.
Old Jan 31, 2021 | 09:20 PM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
75 L82 doesn't have a O2 sensor factory stock. So, what are you running?
Old Jan 31, 2021 | 10:17 PM
opichi34's Avatar
opichi34
5th Gear
I had a feeling that might be the case. I'm new to these C3s, here's a picture of it. I'm guessing the last owner just cut it?
Old Jan 31, 2021 | 10:43 PM
kansas123's Avatar
kansas123
Kinda sorta looks suspiciously like an O2 sensor though....Usually it's further down the trail than that on the exhaust, and certainly was not something that was stock in '75.
Old Feb 1, 2021 | 09:34 AM
resdoggie's Avatar
resdoggie
Had a 1976 L-82, 4-sp
Royal Canadian Navy
I don't think that engine was born with your car. What are your plans for the engine? Mods? Leave as is?
Old Feb 1, 2021 | 09:59 AM
opichi34's Avatar
opichi34
5th Gear
No mods as of yet. Goal is just to get everything working as it should. I've already done plugs, wires, oil, and am looking into vacuum leaks soon ( which there are quite a few).
Old Feb 1, 2021 | 10:19 AM
opichi34's Avatar
opichi34
5th Gear
Previous owner just verified that the engine is not original, I'm going to look for a VIN on the block.
Old Feb 1, 2021 | 12:19 PM
Big Block Dave's Avatar
Big Block Dave
Manifold is not a corvette manifold.
if the manifold was born with that motor, a non center bolt valve cover motor, the latest car it can be out of is a 1986. Could be a tpi or crossfire motor from a camaro, but pure speculation..
Old Feb 1, 2021 | 01:12 PM
augiedoggy's Avatar
augiedoggy
Well on the positive side, at least your further ahead should you choose to put an A/F meter gauge in the vehicle for carb tuning and monitoring... I have to have a bung welded into my sidepipes to install the meter I got for christmas.. could be a roller cam engine as well which would be another plus.
Old Feb 1, 2021 | 01:27 PM
Big Block Dave
Roller cam doesn’t appear until 1987 in sbc
Unless someone swapped in a retro fit hydraulic roller, or put a set of 86 and older heads on a later block, I’m going to say unlikely that this has a roller cam.
Old Feb 1, 2021 | 02:08 PM
augiedoggy's Avatar
augiedoggy
I was going on the sense that we didnt know what heads were on the engine. The old darts on mine have bolt holes for either valve cover design. Your right though, they are likely GM stock heads.
Old Feb 1, 2021 | 03:22 PM
Big Block Dave
we really know nothing right now... it could be a 305. It could be a 400. The heads could be fancy aftermarket heads. Anything really is speculation.
For the owners sake I hope it’s at least a stock 350
To O2 Sensor Plug location
