Quick Brake Caliper question
Old Feb 9, 2021 | 11:08 PM
ZAKsPop's Avatar
ZAKsPop
Default Quick Brake Caliper question
2 of my calipers are leaking because the car was sitting up a long time. I am thinking about buying rebuild kits with the o-ring upgrade. I saw a video where they were doing this upgrade but the guy said it is only possible if the calipers are lined with stainless steel. Is he correct or FOS. If he is correct, is there an easy way to tell if they are lined with stainless steel other than disassembling the caliper?
Old Feb 9, 2021 | 11:44 PM
69L88's Avatar
69L88
You need to remove the dust seal and expose the top of the cylinder bore to see if they have been sleeved.
Old Feb 10, 2021 | 12:26 AM
Bikespace's Avatar
Bikespace
I'd say YouTube guy is correct. If they are not sleeved, send them back as cores. If they are sleeved, I used CSSB Inc. high-heat O-ring rebuild kits on my car (with sleeved Delco Moraine castings). They only sell on eBay now, though.
It'll be obvious once you have them apart.
Old Feb 23, 2021 | 11:57 AM
ZAKsPop's Avatar
ZAKsPop
Old Feb 23, 2021 | 08:02 PM
Sayfoo's Avatar
Sayfoo
I don't see how it would matter if they were sleeved or not, as long as they are the correct diameter and the bores aren't pitted.
If they aren't ss sleeved, there is a good chance that they are pitted and may not be suitable to rebuild.
Old Feb 23, 2021 | 09:35 PM
ZAKsPop's Avatar
ZAKsPop
I want to upgrade them to o-rings. They must have SS sleeves for this. At least that is what I read and all the videos I've watched say.
Old Feb 23, 2021 | 09:51 PM
Bikespace's Avatar
Bikespace
As @69L88 said, you need to remove the dust seals and look at the bore. You should see the stainless liner, if present. The dust shields should be part of your rebuild kit.
Old Feb 23, 2021 | 10:10 PM
GUSTO14's Avatar
GUSTO14
Ronnie, I would wager that the odds of your '69 having un-sleeved calipers is slim and none! I replaced my first set of leaking calipers with SS sleeved ones in 1979 and that was on a '77 with less than 20k on it. To my knowledge the factory never installed SS sleeved calipers, even after they knew they would be problematic. But the last ones were installed in '82, some 39 years ago, so the odds of finding un-sleeved original calipers are not in your favor. If you did find a set, the cast iron bores would probably be far too corroded to hone and reuse. Which is why the SS sleeved calipers appeared in the first place.
Buy the rebuild kit and when you tear the caliper apart it will be readily evident if they are sleeved - they will have very minor if any corrosion and can probably be cleaned up with some crocus cloth if they do. Be sure to include new pistons as most have aluminum pistons which still corrode even if the bores don't.
If yours are un-sleeved, send them off and have them sleeved, I think Lone Star still offers that service, or turn them in to your nearest NAPA for new calipers which will probably already have the SS sleeves in them anyway.
FYI; if you do decide to rebuild, loosen the caliper half bolts while the calipers are still bolted to the car. Trying to break them loose on the bench can be a real challenge!
Good luck... GUSTO
Old Feb 24, 2021 | 01:30 AM
ZAKsPop's Avatar
ZAKsPop
Good luck... GUSTO
Thanks. That makes since. I do think they are rebuilt because the pistons look pretty new. They have set up and 2 of them started leaking so I figured I should put in the o-rings. Here is a picture I took of the drivers rear caliper.
Old Feb 24, 2021 | 01:33 PM
Sayfoo's Avatar
Sayfoo
Well, if it's on the internet, it must be true.
I wonder how a O ring can tell the difference between different kinds of metals?
Old Feb 24, 2021 | 07:39 PM
ZAKsPop's Avatar
ZAKsPop
TFIIK but the video was from Ekler's so I figured (hoped) they knew what they were saying.
Old Feb 25, 2021 | 07:43 PM
Sayfoo's Avatar
Sayfoo
IF I had good original bores--no pits--I would use them.
Perhaps you could call Ecklers to get their take on it.
Of course, if you have original bores with pits, the point is mute.
I've found, just because a company has been in business a long time, doesn't guarantee that they are 100% accurate.
The older I get, the less I believe.
Good luck either way.
Old Mar 2, 2021 | 10:08 PM
SharkAttack's Avatar
SharkAttack
I've put O-rings in calipers that were not stainless sleeved because the bores were clean with no pitting or damage.
Those O-rings far outlasted the lip seals I had previously replaced, even with C3's that were rarely driven.
I've heard the same thing the Ecklers video claims, and stainless sleeved bores are probably recommended just to ensure there are no pits or damage that could cause brake issues. There's a lot of liability risk related to automotive brakes.
A standard rebuilt caliper may not be sleeved, but should have new pistons, piston seals, O-rings for where the caliper separates, and dust seals.
To Quick Brake Caliper question
