69 headlight door removal question
Old Mar 7, 2021 | 09:05 PM
69ttop502's Avatar
69ttop502
Default 69 headlight door removal question
So I have my freshly restored 69 running and driving well. In getting my headlights working with Richard 454’s terrific electric conversion working, I noticed my driver side door frame has some casting flash that is hitting the body opening when it opens. I was wondering if I can remove the door while leaving the rest of the assembly on the car. If I remove the 3 screws on each side to remove the nylon bearings, and remove the linkage, will it pull to one side far enough to come out? I really only need to be able to lift it enough to be able to get a dremel on it to get rid of the flash. My pivot collar allen heads, of course, are pointed to the rear, so not sure I can get a wrench on them to loosen. I really don’t want to have to remove the assembly on a freshly painted car. Thanks for the help.
Bill
Old Mar 7, 2021 | 09:33 PM
Plasticexperience's Avatar
Plasticexperience
First if you raise the headlamps you can get to the Allen screws and then you can disconnect the pivot bolt. . When I put mine in I went through the front without the grill attached. I am not sure if you can pivot them out through the top.
Old Mar 8, 2021 | 08:00 PM
69ttop502's Avatar
69ttop502
Thanks for the help. Doesn’t seem it is possible by the lack of responses. I guess I am just going to have to get in there and see f I can loosen it enough to raise it and get the dremel behind it. Always something.😞😞
Old Mar 12, 2021 | 09:36 AM
old white 74's Avatar
old white 74
Hi just a note of caution I was taking mine out of a 69 and as i tried to loosen the the bolts that hold it on the front by the bumper i broke the cast aluminum housing. Before loosening the other side i drilled a 1/8 whole through the steel bracket and light housing then put the drill bit in then got the bolt loose. It keeps the casting from twisting and breaking.
To 69 headlight door removal question
