I am planning to swap out the power brakes on my '74 small block 4 speed to manual. I understand a different bracket is needed for the brake light switch. I see in the Eckler's catalog an adjustable proportioning valve with a switch on it. Has anyone used this product? I am refurbishing the entire brake system, lines, master cylinder, calipers, and rotors if they need it.
I have used an adjustable proportioning valve before, but that was on a race car.. With twice as sticky as stock tires it tended to lockup the rear tires under 1.2G braking. There was so much front weight transfer that the rear would unweight so much it would skid.
On a street car just use the original type part.
I was thinking this would be easier than fabbing up the bracket for the switch, apparently they don't make them, plus the adjustability, while maybe not necessary, wouldn't hurt?
I think y'all are missing the point of my question. I need a different brake light switch, and this seems like a good way to get that, and adjustment to boot. For a hundred bucks, can it hurt to try it?
I fail to see why the brake pedal mounted switch would be any different for power brakes or std brakes. If the pedal itself is different then I'd just fab a new bracket and not fool with the proportioning valve.
The brake light switch is on the pedal assembly and there are two different brackets depending on power or manual brakes, but they use the same switch, so your switch is still good. The manual bracket is longer since you have to use the top hole on the pedal for correct pedal ratio. The switch on the distribution block/proportioning valve is for the warning light. The different pedal brackets are readily available.
I have used those low pressure brake light switches on Street Rods for years........my advice? Keep a spare in the glove tray as they are about as reliable as a 19 year old showing up for work.
I would somehow make your electric switch work.......
That was my understanding, except I was under the impression the bracket for the brake light switch was hard to come by. You don't happen to have a part number? I also now understand the switch on the valve is for the dashboard warning light, not the brake lights in the rear bumper. Thanks guys for clearing that up for me.
Richard, thanks for the pics.
I thought you wanted to convert it to a low pressure type switch....hence my reply.
