Weak HEI Spark (Chevy 454)
1) Run a "jumper" ground wire from the distributor to a good chassis ground or Batt negative.
2) Pull the Ignition module out of the distributor and do whatever you can to "improve" it's connection to ground.
3) Replace the Ignition Module (and don't go super cheap).
4) Replace the coil with a new one (one that doesn't have a super low resistance).
5) Say "Screw It" - get a replacement HEI distributor - with module and coil - and install it.
Tach wire @ Coil, Batt wire is ground 10V /div
Tach wire with chassis (coil core) as ground . 10V /Div
Tach wire @ coil, scope ground on Batt. 10V / div
The Ignition Module uses transistors to switch the coil to ground and to break that circuit. I don't know if the Ignition module needs to be "powered" to work properly ??? Just a though...
And IMHO - Just because the coil is new is not a Guarantee it works. A now working "New" Ignition Coil would not be a first...
It is always wise to consider that new components can be defective, and I would not bet my lunch on this "new" coil being pristine. However, it ohms out like a good coil, and I'm generally not unlucky enough to get a bad component out of the box (although I understand that it can happen) . Given I don't understand how it (or the one before it) could of ever worked with with 2 flimsy ground connections on paint (unless the mounting screws connect to a ground within the distributor cap) , perhaps I've damaged it somehow. (every piece of documentation I've ever seen on those coils cautions that they need 2 robust grounds or they won't work ).
I'm going to give it some more thought, but unless you or the gallery can see something wrong with these waveforms, I'm going to consider buying another new coil ...... Thanks again
Also check the color of the leads on the coil with the leads on the pick up. If you have a yellow and red lead on the coil, then the pick up should have a yellow and green lead. The colors signifies the polarity of the coil and the pick up, and they must match. If the pick up has a white and green lead, then the coil must have a red and white lead. If all of the above checks out, then it's either the coil arcing internally, or the module not triggering properly. The HEI system is pretty simple, and assuming that you didn't change any wiring, it has to be a component, especially if it was running before, Pep Boys or Autozone will load test that module for free.
PS I just re-read your post, I examined the rotor too, and held it up to the sunlight, I didn't see anything wrong with it or any holes (again, spark testing from the button would eliminate that from the chain) . It seemed to have a high resistance from the tempered center piece that touches the button and the rotor point. You don't happen to have a resistance reading on a good rotor? thx
There are three kinds of plug wires - Solid conductor, Suppression, and Spiral Wound. The solid conductor are good only for racing - and on non-computer controlled cars - they tend to create a lot of RF energy - which can screw with computers. The suppression wires like you have are what OEM's have been putting on cars for years now. They work. The Spiral Wound wires use a conductor that is wound around the wire core - so a 2 foot plug wire may have 25 feet of wire in it - but winding around the core tends to null out the RF - so the can be used on computer controlled engines, and typically have resistance of about 50 ohms per foot. They tend to work "better" then the carbon core wires - but are more expensive.
I'd say - the issue is probably NOT your plug wires. The resistance of the "button" in the cap sounds a little high - but not crazy.
Test set up for HEI ignition, (HEI test spark plug terminal held against rotor brush/button with old spark plug boot, jumper from alligator clip to ground) it wouldn't fire btw, but a conventional plug would.
Picture of advance weights/springs, ICM on left with pick-up coil connector bottom left.
reported on these message boards that cut-off the engine while running is the ICM (ignition module) , I pulled it off and will take it to AZ tomorrow (I don't think its the problem, but I'm running out of things that qualify) . If any of this raises any obvious red flags, let me know . Thanks!
I was hesitant to to remove the ICM as it appeared to me to be working properly (via oscilloscope waveforms and test-light blinking on the coil primary) I wanted to avoid simply shotgunning with replacement components unless I was desperate. Given I was running out of suspected trouble points, and that there were many instances reported of the ICM failing while the engine was running fine cruising down the road (with was my failure experience), I had nothing to loose by getting the vehicle's ICM tested yesterday. The ICM failed on the tester @ AZ. The tester performs a chain of tests and signals that they passed or failed by lighting a series of green lights or red lights respectively, with my module, it got towards the end and failed the test marked "energy". (I can only guess what this is, but my guess would be the tester makes the module either fire a coil or observes if the output performs properly on a coil-type load) . The AZ guy ran the test 3 times and it repeated. Interestingly when finished, the module was too hot to touch (I've read accounts of where guys with rough running vehicles took their module in for a test, it passes and when they re-install it the engine won't run at all, Id guess exercising a vintage module w/o a heat sink isn't good for its longevity) . I was still skeptical that the module was the issue, but given most of the faulty tests I've read about determined a bad ICM to be good (not vice-versa) , and that its a common fail mode while running, since I had 2 data points now I installed a new module (a AC Delco replacement btw) with successful engine start. I'm still confused why the bad module gave me a (what I thought) was a good coil pulse. I've attached the pics of what a good ICM output looks like, the only major difference I can see from the bad one is that the dwell (the negative going square wave) is about half the width of the same wave on the "bad" module. I also removed the new 1 ohm rotor brush (button) and replaced it with the original ~
ICM output wave-forms from new ICM while engine cranking (ignition working properly)
ICM output wave-forms, new ICM, engine running
3K ohm brush. I'll make sure modules are on my redundant parts list for road trips. I'll donate these pics to the forum archives here. I appreciate everyone's inputs, if you have more, I'd love to read them. Thanks!
