Jeep steering box conversion
Old Mar 17, 2021 | 09:36 AM
Danny.reamer's Avatar
Danny.reamer
Default Jeep steering box conversion
Does anyone have a parts list and a step by step install on the Jeep steering box conversion? I’ve found lots of info but can’t find this info and most posts for some reason won’t show the pics.
Old Mar 17, 2021 | 09:54 AM
interpon's Avatar
interpon
IMO search google..
C3 corvette (insert subject) will lead you 90% time this forum..and your answers. i never have luck searching the forum search bar.
a few examples below, or even PM some of the original posters have been helpful to me as well..(old pics etc..)
Jeep steering box conversion - CorvetteForum - Chevrolet Corvette Forum Discussion
Jeep Steering Box Conversion - CorvetteForum - Chevrolet Corvette Forum Discussion
C3 Steering conversion - CorvetteForum - Chevrolet Corvette Forum Discussion
Jeep steering box adapters - CorvetteForum - Chevrolet Corvette Forum Discussion
Jeep Steering Box Install - Page 2 - CorvetteForum - Chevrolet Corvette Forum Discussion
Old Mar 17, 2021 | 10:40 AM
bradleyb66's Avatar
bradleyb66
The pics issue is because of a PhotoBucket change a few years ago. Now the forum allows direct upload, so newer threads don't have that issue.
Originally Posted by interpon
IMO search google..
interpon, if you want google to return 100% corvetteforum posts, I use google to search the forum directly. If you enter your search words, then put the string "site:corvetteforum.com" (without the quotes), google will only search this forum.
Old Mar 17, 2021 | 10:53 AM
interpon's Avatar
interpon
yup i know..
i do like to see a few other sources as well.. its fascinating to see some members here are also in history and other forums.. kinda cool
Old Mar 17, 2021 | 11:04 AM
Danny.reamer
that is what I have been doing but bun none have a step by step or a exact parts used in doing the mod
Old Mar 17, 2021 | 11:39 AM
Factoid's Avatar
Factoid
The Borgeson box is a Jeep box, so use these instructions:
https://static.summitracing.com/glob...brg-999016.pdf
Old Mar 17, 2021 | 11:51 AM
F4Gary's Avatar
F4Gary
2018 C3 of Year Finalist
2016 C3 of the Year Finalist
Or just buy the Borgeson conversion kit.
Old Mar 17, 2021 | 03:15 PM
Danny.reamer
I’ll check it out.
Old Mar 17, 2021 | 05:21 PM
bazza77's Avatar
bazza77
The Jeep box isn't the same as a Borgeson box (For install) .
The Jeep will still have 4 mounting points where as Borgeson cuts that whole plate off and welds on another that has 3 holes that match the C3 frame.
If you Don't have any parts yet , the Borgeson, while more expensive, bolts straight in , the jeep can be bought cheaper , but you will need to fabricate some adaptor plates to turn 4 holes into the 3 matching holes. Both ways need the steering column to be shortened.
Old Mar 17, 2021 | 07:11 PM
Danny.reamer
I’m not concerned about any modification I was just wondering if there was any more parts needed other then the pitman arm? Is there any modification needed to the steering rod or power steering lines?
Old Mar 17, 2021 | 07:27 PM
Bikespace's Avatar
Bikespace
Unless the Jeep box is different than the one Borgeson modifies, I think the Pitman arm is optional. You can use a power steering pitman arm with the Borgeson end link (this is what is in my 79, with Borgeson P/S). Presumably you could use a manual pitman arm with a manual steering drag link (this is what is in my 80, only with a manual steering conversion, not Jeep/Borgeson P/S).
You need specific power steering lines. The Borgeson kit works with the Borgeson box, and may be the same for you. There are ferrule adaptors that come with the kit.
Here's some hose info (hopefully you don't have an 80), and the longest running Borgeson install thread:
https://www.corvetteforum.com/forums...ing-lines.html
https://www.corvetteforum.com/forums...n-install.html
Old Mar 17, 2021 | 10:27 PM
Danny.reamer
thank you that’s what I was needed to know
Old Mar 17, 2021 | 11:45 PM
7T1vette's Avatar
7T1vette
When folks want to re-engineer their C3, it used to be called DIY (do it yourself). Nothing wrong with asking for potential problem areas or details on a specific modification...
But why would anyone expect that a detailed 'recipe' of all required parts & their numbers and a detailed step-by-step process would be available to them???? Everyone else who has done the same change did it for themselves. No need to go with detailed photos and documentation for SOMEONE ELSE!! Geez.
Old Mar 18, 2021 | 07:20 AM
Danny.reamer
Because that’s what people do!!!!!!!!!!!!!!! If a mod has become popular most of the time someone will take the time to do a install to help the next person out. I’ve done it before so I guess it’s not out of the realm of possibility to ask if someone else had done the same for this mod. Plus I’m pretty sure that’s kinda what this forum if for and to share the knowledge. So do you have any actual input on the original question I asked for or do you just like trolling through pages putting your 2cents in on something that wasn’t asked for!
Old Mar 18, 2021 | 07:36 AM
augiedoggy's Avatar
augiedoggy
Is this a joke? There are literally thousands of DIY step by steps like this in thousands of forums... Not to mention about half of you tube videos in existence..
To Jeep steering box conversion
