Replace brake booster? What about a seal?
Old Mar 22, 2021 | 02:04 PM
aalmans's Avatar
aalmans
Default Replace brake booster? What about a seal?
Hi all,
I was removing my master brake cylinder in order to replace it with a new one and replace all brake lines at the same time only to find out it apparently had been leaking:
Does this mean my power booster is now shot too?
Also my new master cylinder did not come with any seals. Should there be one? It's a 1981 C3. I have seen reports it should not need a seal, or a rubber one or a foam one.
What is required?
Old Mar 22, 2021 | 02:40 PM
kodpkd's Avatar
kodpkd
In the 68 assembly manual and the parts web sights it shows a gasket and a retainer seal between the booster and MC.
Old Mar 23, 2021 | 01:50 PM
michaelroy's Avatar
michaelroy
Not needed
Old Mar 23, 2021 | 03:23 PM
aalmans's Avatar
aalmans
Originally Posted by michaelroy
Not needed
Looks like these are the remnants of the old one:
They look like the ones from the 1981 AIM indeed:
Are you sure these are not required? Why were they there in the first place?
To Replace brake booster? What about a seal?
