Huge "thump" selecting reverse (TH400 Auto)
Old Mar 23, 2021 | 01:36 PM
Specialbrew's Avatar
Specialbrew
Default Huge "thump" selecting reverse (TH400 Auto)
Hi Guys,
​​​​​​When I select reverse, I get one hell of a thump...but only when warm or hot. Fluid level is good.
Any suggestions?... I admit to knowing very little about auto boxes so it's a mystery to me. I had a short video here...make sure you "unmute" to hear it.
Old Mar 23, 2021 | 02:20 PM
C3 Stroker's Avatar
C3 Stroker
Could be a couple different things, but when I developed that exact same problem, it was my rear end (believe it or not). Have someone outside the car listen closely, since it's hard to pinpoint from inside the car. Could be a mount loose or internal trans line pressure too high.
Old Mar 23, 2021 | 02:23 PM
Specialbrew
Thanks...I'll check it out. Just a bit odd that it doesn't do it fully cold.
Old Mar 23, 2021 | 02:26 PM
bradleyb66's Avatar
bradleyb66
To me, that sounds like the front differential mount is shot, or maybe the rear transmission mount? Easy fix for either if that is the case. It could be happening only when it's warm because the transmission probably slips a little more when cold, so no 'snap' when it goes into reverse.
http://repairs.willcoxcorvette.com/1...-instructions/
Old Mar 23, 2021 | 02:29 PM
C3 Stroker's Avatar
C3 Stroker
I'm aware......mine didn't do it cold, either......and only in reverse. I was convinced it was the trans, but a rear end expert assured me it was in the rear and showed me the loose parts when he took it apart....he was correct and the problem was solved.
Old Mar 23, 2021 | 03:22 PM
Lamouree351's Avatar
Lamouree351
sounds like the snubber bushing on the front of the diff is shot. mine was doing the same thing before I replaced it
Old Mar 23, 2021 | 03:34 PM
mongoose87's Avatar
mongoose87
What is your idle rpm when the car is hot?
What i noticed is when my car is cold, my idle is around 850 rpm, and shifting into reverse is no issue.
After it's fully up to temp the idle goes a bit higher, maybe 1000rpm, and creates a much bigger thump when going into reverse because at that higher rpm the torque converter has more resistance and thus slows the engine down more.
Old Mar 23, 2021 | 08:06 PM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
Replace the easy/cheap parts first. Let us know if it improves (somewhat).
Old Mar 23, 2021 | 09:02 PM
Peterbuilt's Avatar
Peterbuilt
Default Something to check
Old Mar 23, 2021 | 10:48 PM
7T1vette's Avatar
7T1vette
What is the idle rpm of the engine? {I assume it is an automatic car.} The reverse shift 'thump' results from too much available torque coming from the engine during the shift and can be enhanced when the rubber 'snubber' mount is missing/worn out/damaged. If you have an upgraded engine with a relatively high idle speed, that will definitely cause a thump.
Old Mar 24, 2021 | 04:51 AM
Specialbrew
Yes, I would say my hot and cold idle speeds are the same as yours. I'm going to change the months as suggested and go from there.
Old Mar 24, 2021 | 07:24 PM
Boomer880's Avatar
Boomer880
Isn't your RPMs backwards? Mine is higher when cold, and then either drops down as the engine warms, or i kick it down, and I am at about 650 RPMs when warm. Around 1200 RPM when cold.
Old Mar 24, 2021 | 08:09 PM
Eric P's Avatar
Eric P
If everything checks out ok it could have a broken wave plate in the reverse clutch of the transmission
Old Mar 25, 2021 | 05:56 AM
Specialbrew
You would think so but mine is certainly higher when warm.
Old Mar 25, 2021 | 07:01 AM
doorgunner's Avatar
doorgunner
"Reverse" them.
Old Mar 25, 2021 | 07:03 PM
mongoose87's Avatar
mongoose87
Sure, but you are talking about when the choke and the high idle is engaged on the carburetor. I have mine set so it kicks down after about a minute; the engine is about 100 degrees, then warms up to the normal operating temperature at 180 degrees.
The point is, if you have a higher idle, expect more of a thump getting into reverse, or really putting into either drive or reverse.
To Huge "thump" selecting reverse (TH400 Auto)
