A Basic Header Question
Old Dec 12, 2002 | 03:15 PM
OHSIXX's Avatar
OHSIXX
C2 of Year Finalist (performance mods) 2019
Default A Basic Header Question
I am completely in the dark when it comes to headers, but have decided to order Hooker Headers from Jet Hot Direct with the Sterling finish.
What else is needed ? I assume gaskets, bolts, and maybe brackets.
The car is a 72 w/ AC. Once I get everything together I will be taking it to a local muffler shop for installation. Can someone give me a little list of everything that is needed, so I won't be completely dumb when talking to Jet Hot ?
Old Dec 12, 2002 | 03:36 PM
BB wowbagger's Avatar
BB wowbagger
Default Re: A Basic Header Question (OHSIXX)
Gaskets should be delivered with the headers. Good headerbolts is a must....I run with ARP..
Old Dec 12, 2002 | 03:42 PM
Stewart's74's Avatar
Stewart's74
The supplied gaskets are junk. Throw them in the garbage and buy a quality set. Percy's, Fel-Pro etc.
A good set of locking header bolts (Stage 8) would also be a good idea.
Old Dec 13, 2002 | 07:20 AM
J75's Avatar
J75
Default Re: A Basic Header Question (Stewart's74)
:iagree: Good gaskets are a must,also bolts or a stud kit and collectors.If you have the long compressor,you will just mod. your bracket.
Old Dec 13, 2002 | 11:38 AM
OHSIXX's Avatar
OHSIXX
I found the Stage 8 header bolts in Jegs, but having a little trouble finding the right FEL-PRO gaskets.
Can someone post the correct Jegs or Summit PN for the gaskets?
Old Dec 13, 2002 | 11:47 AM
PRNDL's Avatar
PRNDL
I dont even know if he is still there, but Todd at JET-HOT was giving siginficant (10% ?) discounts to corvette forum members but you have to ask. :) MJ
Old Dec 13, 2002 | 12:24 PM
OHSIXX's Avatar
OHSIXX
Default Re: A Basic Header Question (MNJack)
Yes! Todd is who I am talking too. He left on vacation yesterday until the 23rd, so thanks for the tip.
Still need that gasket number. :)
Old Dec 18, 2002 | 12:44 PM
LemansBlue68's Avatar
LemansBlue68
Get good header bolts!! Preferably in stainless. The ones that come with the hooker headers are absolute junk and are not long enough to boot! Get as much thread engagement as you can or you'll be stripping the holes in your heads. I've found stainless allen head set screws work excellent. I drill them and safety wire them for good measure. They clear the tubes well too, with no socket clearance issues.
Good gaskets are a must too. Gasket compression and then relaxation is why the header bolts keep coming loose. I swear by Fel Pro but there's other good ones out there. I wouldn't touch Mr Gasket stuff with YOUR 50 ft pole!
Old Dec 18, 2002 | 04:18 PM
AlwaysWave's Avatar
AlwaysWave
Cruise-In III Veteran
Check out the Summit catalog. I got aluminum header gaskets from them are working out great.
Old Dec 18, 2002 | 04:37 PM
Ryan77's Avatar
Ryan77
Default Re: A Basic Header Question (AlwaysWave)
You will probably need a special A/C bracket, ask JetHot or call Jeg's as the too sell the Hooker Headers.
To A Basic Header Question
