For the 82 CFI guys...
THE STORY... I had a guy call me from a dyno shop in WA state a number of years ago and asked me about this issue he was seeing on the dyno with an 82 that was running a similar fuel system as mine and wasn't happy with what was going on. At the time, I never had an issue like that or at least not to that extreme. We talked about this for several days back and forth and finally he asked me if I had seen a video on this subject and sent me the link. (I wish I could find this video and post it) It is a really good video and explains why this all happens and why the length of vacuum hose changes the rpm range lower or higher. It's all about flow/fluid dynamics and physics.
Anyway, my 82 does have a small issue, but it doesn't bother me nor I'm I concerned since it is at a low rpm range that I hardly ever drive around at that rpm constant speed. So...fast forward a number of years here on the C4 forum with an 84 CFI vette a guy I know on there who has a thread dealing with his Dynamic EFI EBL Flash II tune which is pretty good and his motor does run pretty good with his 4+3 setup. So he changes a few things on his motor and the motor starts running like crap. He trouble shot the tune, fuel system, ignition etc... with no apparent success. I had been following the thread on and off for a while, but never really read the entire thread to analyze what was going on until lately. I thought, I wonder if... this sounds familiar. I had the owner call me and we talked about the real issue he was having and I told him I think I know what is going on and why your motor is running like crap. I know this "may" sound strange/odd, but check this out and let me know what the results are.
Well, I was right, he played with the vacuum length and saw the rpm ranges change and removed two fuel hard-lines from the "Y" fuel feed block to both TBs with rubber lines and the issue went away. Here is the link to his thread and his fuel issue is around page 3 I think and into 4 and then finally to page 5. So for any of you guys that are running this system and have this issue, change the fuel feed lines to rubber so the injector pulses can be absorbed and the issue will go away or diminish greatly. Enjoy!
84 CFI fuel issue
STICKY LINKY
I was considering running a fuel pressure regulator in the aft part of the car (to recirc the fuel back to the tank back there) and using the old small steel line as a vacuum source to regulate pressure. Now I'm curious how that long of a vacuum line would affect the system? Curiouser and curiouser. Good story and interesting side-effect of trying to make something better creating problems.
Jebby, this was a head scratcher for sure and at first didn't believe it until I started digging into the issue. WOW! It is a real thing and crazy how stuff happens and works out when you least expect it. I need to see if I can find that video, it is really good to watch.
The EZ-EFI comes with like a 15 foot extension and a fuel pressure sensor that is indicated on the display. Adjusting it would be relatively easy..... I just don't know how it would function.
don't recall ever even seeing one installed in the rear, but maybe I didn't look close enough. I would install it under the hood so you can see it and the gauge, but that's just me. Your vacuum line if used will be much shorter depending on where you mount it as well.
