Power issues
Old Apr 14, 2021 | 03:53 PM
Kincad's Avatar
Kincad
Default Power issues
I am currently having issues with power in the low range but once i hit 3rd gear it takes off like a bandit. Could this be caused by my intake manifold? It currently has an edelbrock torker ii 2-0 with edelbrock 1407 carb. Oh i have 74 454.
Popular Reply
Apr 15, 2021, 08:00 AM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
Jebby makes a good pint, did you just do a tune up recently?
BTW...I DO make a good pint....come on down sometime and I’ll pour ya one!
Jebby
Old Apr 14, 2021 | 04:59 PM
Factoid's Avatar
Factoid
A Torquer II power range doesn’t start until 2500 rpm and comes on strong at 3000. Almost sounds normal to me.
Old Apr 14, 2021 | 05:52 PM
68post's Avatar
68post
Do you mean that in first and second gears it doesn't pull as hard as it does in third gear ?
Old Apr 14, 2021 | 07:32 PM
Kincad's Avatar
Kincad
yea kind of. It's hard to explain. From a dead stop, if I hit the gas, not hard but enough, it bogs hard-core then when I reach hywy speed and hit the gas, it takes off
Old Apr 14, 2021 | 07:56 PM
blue427's Avatar
blue427
I doubt if it's the torker as I had one on my 427 and they're good to about 6000rpm.I would look for a vacuum leak which has more issues a low speeds then after you're up to speed or timing not set right or not advancing fast enough.
Old Apr 14, 2021 | 09:50 PM
leigh1322's Avatar
leigh1322
Old Pro Solo Guy
Do you still have the emissions timing retard system for the lower gears still hooked up?
Old Apr 14, 2021 | 11:08 PM
Kincad's Avatar
Kincad
do you mean egr? That, I have no clue. I am still learning about all this and will research more.
Old Apr 15, 2021 | 06:09 AM
Kincad's Avatar
Kincad
So I have been reading a bunch of stuff and it could possibly be my carb is not tuned correctly. I was also thinking about the intake manifold because it is rated for higher rpms. I'm going to start with the carb and see where that leads. Thanks so much for the help!!! I definitely have a lot more to learn but I'm gaining
Old Apr 15, 2021 | 07:16 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
It doesnt sound like its all your engine, it sounds like your gearing too. You are using the same rpm range in every gear. you run your motor up to say 2500rpm to 3000rpm , then shift, run it up again , then shift. Why is that rpm different than your rpm on the highway? It could be that your gearing s so high for better mileage or to keep the rpm at highway speed down that it is making your city driving suffer.
To tell if its your carburetor giving you the bog, you need to get up to say 50mph in fourth, shift down to 3rd and floor it. If it bog then its the air flap openning to fast and giving you a lean bog. That is what the old quadrabog was and edelbrock has the same style air flap on the secondaries. On a quadrajet the airflap has an adjustable spring and the new edelbrock AVS carbs have and adjustable spring on that door. the regular and older edelbrocks do not.
That same symptom could also be your accelerator pump is not working or on the weakest setting.
Old Apr 15, 2021 | 07:44 AM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
On a stock-ish 454 that manifold has nothing to do with it.......the ports are very small and promote velocity, plus you probably have 17+ inches of vacuum.....that is more than enough to effectively signal the carb from a dead stop.
Your issue is in the tuning......most likely the advance curve is very soft as you do not have power til way upstairs......
Pay little mind to manufacturer descriptions of 30 year old products like the Torker 2O......that intake is a compromise piece designed for nothing but hood clearance......you wouldn't run it on a serious piece as it would be down a ton of power, so saying it has a "power range" is kind of an oxymoron......
One thing I have found is that the damn thing works rather well up to about 450 horsepower.......after that it is a bottleneck.
Jebby
Old Apr 15, 2021 | 07:46 AM
Rescue Rogers
Old Apr 15, 2021 | 07:52 AM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
Almost all of the reason the Q-Jet got the "Quadrabog" moniker was because of the secondary pulloff........this little guy has a predetermined restriction hole in it to limit how fast it releases. If a cheap pulloff or a bad one is on the carb it will cause a bog when the secondaries attempt to open. The delay in the pulloff keeps the air valve from opening too fast, which creates a momentary vacuum drop and pulls an extra amount of fuel from the secondary booster tubes.....like a secondary accelerator pump in effect. A quick check is to pull the vacuum hose off and push the pulloff in, when you let it go, does it open immediately? Or does it take a second? Then put your finger over the supply hole on the pulloff and push the pulloff in.....does it hold? If it does not pass either test.....replace it.
Jebby
Old Apr 15, 2021 | 08:00 AM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
Jebby
Old Apr 15, 2021 | 11:39 AM
Rescue Rogers
When I get my car running I think I will....I've got to get away for a while, my spelling is suffering
Old Apr 15, 2021 | 05:50 PM
leigh1322's Avatar
leigh1322
Old Pro Solo Guy
Jebbys power valve flap comment is spot on.
Also do not forget to tune the timing curve to GM performance recommendations if you have not already done so. That wakes up the lower rpm ranges in particular.
With a 454 4 spd you should have no bog and that car should scoot.! With any kind of rear gear. Get the distrib tuned "right"
Old Apr 15, 2021 | 06:20 PM
HeadsU.P.'s Avatar
HeadsU.P.
Just curious. What is the history, mileage and age of your timing chain set?
A sloppy chain will retard the cam from 1 -4 degrees depending on the severity of the stretch. What that does is, makes your car run like a dog with no low-end grunt.
But will also scream at the higher RPMs.
Old Apr 15, 2021 | 07:35 PM
Kincad's Avatar
Kincad
I have been wanting to go thru the entire engine just to make sure everything is good, but haven't done it yet. For timing chain,, I have no idea. Ad far as I know it's all orginal inside. Whom ever had it before me pulled the engine and tyranny and painted it purple so I'm assuming they went through the block. From what I'm to that happened in the late 90's. My mechanic checked timing and compression ratios and said they are within in the norm, that is another reason I'm holding off from pulling the engine again
To Power issues
Old Apr 15, 2021 | 07:50 PM
HeadsU.P.'s Avatar
HeadsU.P.
Ok. A fairly simple test to see if the timing chain has excess slack is to:
Remove 3-4 plug wires from dizzy cap and lay cap off to the side.
If you can get a ratchet / breaker bar on the harmonic balance bolt, turn the crank a bit clockwise noting the rotor.
Then reverse the crank and watch the rotor again.
If it took several crank degrees rotation for the rotor to move, you have a sloppy chain.
Old Apr 15, 2021 | 08:36 PM
Bikespace's Avatar
Bikespace
Automatic I presume? If you can force your RPM higher, does the car behave like it does in 3rd gear?
Perhaps you can give us some more info (RPMs, tune/timing, etc) to separate the transmission from the engine. if you aren't seeing 3000 RPM until 3rd gear, your secondaries probably aren't opening. Otherwise, is there a trans-related vacuum leak that could cause issues?
Old Jun 27, 2021 | 11:27 PM
Kincad's Avatar
Kincad
Default ***update***
I would to thank everyone that responded to my post a few months ago. I put a lighter spring set in the distributor, which helped a lot!! I found out that 3 of my spark plug wires were burnt through so only running on 5 cylinders. Since then I bought ceramic coated wires plus put on heat shield sleeves. I took off the headers and found the gaskets were deteriorated causing exhaust leak. I decided to back to stock manifolds. And lastly I put a brand new exhaust system on. Needless to say it's running really well and once I get the smaller stuff tuned in, she's going to be a monster!!!
thanks again for everyone's insight.
