Carb Hose
Old Apr 17, 2021 | 12:44 PM
78 ettev's Avatar
78 ettev
6th Gear
Default Carb Hose
I'm reassembling my silver anniversary, L48 after 21 years. I have a 2" long, 3/8" ID black hose that I have a note on one end that it attaches to the carb. fitting under the gas filter area. What does the other end connect to? I thought that fitting is where the PVC valve hose attaches? Thanks for any help. A lot of the older threads talk about links and pictures, both of which don't work.
Old Apr 17, 2021 | 12:49 PM
PJO's Avatar
PJO
Veteran: Marine Corps
Should go to you PCV valve on the forward left valve cover. About half way on the hose should be a "T" with another hose attached to it going to your vapor canister..
