Oil pump problem
Old Apr 21, 2021 | 08:08 AM
Edrush411's Avatar
Edrush411
Let me throw this out there. When I was trying to get the original oil pan off I was tapping it with a mallet and trying to pry it off using the inspection shield as leverage. I didn’t think I was pushing too hard. Is it possible that it could be the scrape from the inspection shield?
Old Apr 21, 2021 | 08:37 AM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
Yep.....very common. Remove it and see if it goes away.
Jebby
Old Apr 21, 2021 | 09:03 AM
Hammerhead Fred's Avatar
Hammerhead Fred
Very possible. The sound in the video sounds just like an inspection shield/splash guard rubbing against the crank end/fly wheel.
Had that once when I ran over a block of ice that fell of the truck in front of me.
Old Apr 21, 2021 | 10:06 AM
derekderek's Avatar
derekderek
also possibly windage tray if one is installed. another piece of sheet metal that can come in contact with rotating assy.
Old Apr 21, 2021 | 05:52 PM
Edrush411's Avatar
Edrush411
I am posting a picture but o e of the tabs to the inspection plate bent into the clutch area. I bent it back and paint it orange. But this was the culprit. I bent it when I was trying to wedge the old oil pan out.
Old Apr 21, 2021 | 05:58 PM
derekderek's Avatar
derekderek
nice when it is a piece of bent sheet metal instead of connecting fods...
Old Apr 21, 2021 | 07:03 PM
Edrush411's Avatar
Edrush411
I agree. Thank you everyone for helping!
Old Apr 21, 2021 | 08:26 PM
lionelhutz's Avatar
lionelhutz
I was able to use a wire to pull down the oil pick line to the bottom of the pan thinking it would solve the problem but the engine sounds horrible. I
This is still a problem. A loose pickup like that will fall out of the pump.
Old Apr 22, 2021 | 04:53 AM
Edrush411's Avatar
Edrush411
I took off the pump and reinstalled it. I put a weld spot on it.
Old Apr 22, 2021 | 10:21 AM
Factoid's Avatar
Factoid
You did well!
So, what is the oil pressure now?
Old Apr 22, 2021 | 12:12 PM
lionelhutz's Avatar
lionelhutz
You've got it then and should be good to go.
