spun main bearing
Old Apr 18, 2021 | 11:41 PM
vetteking777's Avatar
vetteking777
Default spun main bearing
Hey Folks,I could really use some help here.I've built a few engines over the years but never came across this problem.I'm putting together a 383 small block.I bought a block already bored.It looked ok.I took it to my machine shop to have it honed and fit the pistons.When I got it home and set the crankshaft in and started to check my clearences,I couldn't get #3 to plastigage to comfortable clearences,half the journal was two and a half thousandths and the other half was over four thousandths.I took the crankshaft to my machine shop and the crank checked out ok.I brought him the block and he discovered #3 bearing had spun and was seven thousandths out of tolerance.He said the block was toast.Can't that journal be align bored and use an oversize(bigger)main bearing?I'm into this block for around $500 bucks and would like to save it if I could.Any suggestions?Thanks
Old Apr 19, 2021 | 03:14 AM
Gale Banks 80''s Avatar
Gale Banks 80'
There is a couple of diffrent ways to repair this if the block was very valuable. I Sleeve could be made between the Block and Bearing. The Block could be machined out and then built up with Belzona and then have that machined back to the original size The block could be Flame Sprayed which is kinda like Chrome Plating and then that machined back to the original size. The Block could be fitted with all new Main Caps and then Align Bored which would move the Crank upward. There are probably a few more ways of doing it. Only problem is all of these far exceed the Value of the Block, and it would be better to start over. The only cheap way possibly would be to fit one new Cap at the #3, and Align Bore it with the idea that the crank push's down against the cap and not the block.. Even if You could talk a machine shop into doing this it would still be close to the value of a replacement block.
Old Apr 19, 2021 | 04:15 AM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
You could install appropriate thickness brass shim stock between new upper and lower #3 bearing to get the correct clearance around the #3 crank bearing bore.
THEN use Red Locktite to hold the shims in place against the block bore.
Wrap the crank journal with one layer of .001" shim stock and install the crankshaft.
Allow it to remain still for several hours so the shims conform to the crank journal while the Loctite cures.
THEN remove the #3 cap/remove the .001" shim wrap/use plastigauge to check the clearance with the cap bolted in place.
For example:
If the upper half shows .003" clearance...install a .002" shim stock in the upper half of the block bore with Locltite.
If the lower half shows .004" clearance...install a .003" shim stock in the lower half of the block bore with Locktite.
Let us know what you decide and the outcome
Old Apr 19, 2021 | 06:53 AM
L88Plus's Avatar
L88Plus
Do you have pics?
I don't think I have ever seen a block with a true spun bearing that didn't show it upon inspection. Maybe spun just enough to knock the bearing shell out of place and cut off oil to the crank - that'll cook the main saddles and knock the cap out of round - that I have seen a few times. The only indication I had was the oil that was cooked onto the cap and saddle/webbing area.
Maybe now you know why the already bored block was such a good price...hate to say it but I've been there, done that.
Old Apr 19, 2021 | 08:56 AM
stingr69's Avatar
stingr69
Why throw more money at this? Reminds me of that joke where the guy was sitting on the toilet and stands up to pull his pants up and a nickle falls out of his pocket and lands in the bowl. He pulls his wallet out and grabs a $20 bill then tosses that into the bowl along with the nickle......
"Well, I wasn't going to reach in there for just a nickle"
Cut your losses early.
Old Apr 19, 2021 | 01:01 PM
drwet's Avatar
drwet
I just went through the same thing. Fortunately I didn't spend any money on the block before deciding to scrap it. Broken crank and spun main bearing. Otherwise the block looked fine. Consulted with several experienced and knowledgeable engine builders. The unanimous opinion was that the block was toast. I got about $3 for it from the scrap metal dealer.
Don't risk an expensive engine build with a bad block. Cut your losses.
Old Apr 19, 2021 | 01:41 PM
vetteking777
Thanks for getting back to me.I might be dead in the water.I did talk to King Bearing.They said that they have a oversize insert.Depending on what section of the block journal is out of round,I might be able align bore the block and use their set of main bearings.I'm going to talk to my machine shop today.Thanks again for your suggestion!
Old Apr 19, 2021 | 01:42 PM
vetteking777
Thanks,I think you are right!
Old Apr 19, 2021 | 01:44 PM
vetteking777
That's a good one!Yeah i'll probably go to plan B.Thanks
Old Apr 19, 2021 | 01:53 PM
vetteking777
Don't have any photo's.All the mains look ok.There's nothing that really stands out.The machine shop didn't notice it.Nothing seemed wonky untill I could'nt get the clearence that it should have.I spoke to King Bearing and they said the have an oversize insert.I'd have to align bore the block and use their bearings.I'm heading out to talk to the machine shop.Thanks for your suggestion!
Old Apr 19, 2021 | 02:00 PM
vetteking777
Thanks for your suggestion.I think I will probably have to go to plan B.(another block)I did talk to King Bearing and they have an oversize insert.I'd have to align bore the block 0.010 and use their bearings.I'm going to talk to the machinist again and see what he thinks.Thanks again!
Old Apr 19, 2021 | 04:51 PM
lionelhutz's Avatar
lionelhutz
Yes, it's an oversize bearing. Bigger on the outside. You machine shop should have known about them already.
Old Apr 19, 2021 | 07:59 PM
Gale Banks 80'
I think You also have the choice of using 400 Bearings in it. The SBC 400 had larger main bearings both in OD and ID. GM never made it but the aftermarket quickly did they make a Thick Bearing to put a 350 Crank in a 400 Block. So You could have the Block Machined out to the 400 OD and use the Bearings with the 350 ID. Some might say Your going to make the Caps weaker by doing this. This all sounds simple but its a much bigger job than just align boring and the costs of doing it will quickly add up up. If a larger OD bearing is available that only requires an align bore then thats the way to go. Or another block.
Old Apr 19, 2021 | 08:29 PM
vetteking777
Thanks for the suggestion.Yes I think i'm going to go with the oversize bearing.King Bearing makes an oversize insert bearing.The block will have to be align bored 0.010.Hopefully this is the right way to go.Thanks again!
Old Apr 19, 2021 | 08:34 PM
vetteking777
Yeah I would've thought he should have known.He's been doing this kind of work for quite awhile.Anyway I think the fix is in!Ha!Thanks for the suggestion!
To spun main bearing
