Spreader Bar~Where to Purchase?
Old Apr 22, 2021 | 11:32 AM
60 SHARK's Avatar
60 SHARK
Default Spreader Bar~Where to Purchase?
I’ve found that the speed direct site for these is not working, , , so, asking, where are you guys purchasing yours from, and finding them in stock? Thanks for your direction
Old Apr 22, 2021 | 11:36 AM
MelWff's Avatar
MelWff
Did you try calling them or emailing them incase it is purely a web site bug?
Old Apr 22, 2021 | 11:40 AM
60 SHARK's Avatar
60 SHARK
Site isn’t opening to even get contact info
Old Apr 22, 2021 | 11:46 AM
MelWff's Avatar
MelWff
It worked for me
https://www.speeddirect.com/contactus
SpeedDirect
1901 South FM 129
Santo TX 76472
United States
940-468-4536
cservice@speeddirect.com
Old Apr 22, 2021 | 11:53 AM
60 SHARK's Avatar
60 SHARK
Thanks for that. Must be regional issues with the site, as it’s not working for me. I’m not locked into there product, just seems most posts on here point to this brand. Was starting my shopping, thanks ,
Old Apr 22, 2021 | 12:46 PM
ML67's Avatar
ML67
If you can weld or have it welded, Classic Aircraft & Auto makes a high quality spreader bar.
Old Apr 22, 2021 | 01:13 PM
60 SHARK's Avatar
60 SHARK
I am a welder by trade,, 41yrs,, was going to fab my rear strut bars, but found it cheaper to buy them than buy the ends.
But I will look at the priceing at Classic Air&Auto. Thanks for the tip. I'm all about fabing my own stuff, really not difficult for me. I do most of the weld-fab for most of my hot rod buddy's, and others. Actually just did some R&D fab work for Church Boys Chevy II steering rack system, as they are VERY busy with work right now. Appreciate the info,
Old Apr 22, 2021 | 01:15 PM
OldCarBum's Avatar
OldCarBum
Check Van Steel, that's where I purchased mine.
Old Apr 22, 2021 | 01:42 PM
trevorhowe1212's Avatar
trevorhowe1212
I actually just finish installing mine about 10 minutes ago. Less than $60. 19.5 swedged aluminum tube and RH and LH 5/8 Heims from amazon (links below). Couple 5/8"x2" bolts from Lowes. And some 1.5" angle iron I found in the corner of the garage.
Tube:
Amazon Amazon
Rod Ends (I didn't use the tube adapters they come with):
Amazon Amazon
Not a perfect solution since the bolt isn't supported on both side. Puts a bit of bending moment on the bolt instead of pure shear. But I don't think it will be an issue with the size of the 5/8" bolt and 1.5" angle iron.
Old Apr 22, 2021 | 02:02 PM
60 SHARK's Avatar
60 SHARK
Tube:
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Sweet job. Exactly what im looking for, ,, , great for us DIY guys! I'm not raceing the car, just a lil updating. Thanks for replying.
I'm sure it will improve things 👈
Old Apr 22, 2021 | 02:15 PM
trevorhowe1212
Those were my thoughts exactly!
Old Apr 22, 2021 | 02:21 PM
gkull's Avatar
gkull
search online for people that made the end plates and all you have to do is buy the center rod with ends from some place like:
Standard Steel Heim Joint Rod Ends | Speedway Motors, The Racing and Rodding Specialists
My setup
Old Apr 22, 2021 | 03:27 PM
60 SHARK's Avatar
60 SHARK
Thanks guys for all the fast feedback and replies. I was looking in all the wrong places for my info.
With your assistance, I now have ordered what I need for fabrication of my 'Spreader Bar' , all in, for less than $27.00 DELIVERED!
I'll be making it next week. I'll share results when finished.. Thanks to everyone,,,,teddy,,,,
Old Apr 22, 2021 | 04:26 PM
Richard454's Avatar
Richard454
Good deal-
Here's a great thread with a lot if ideas-
https://www.corvetteforum.com/forums...cost-35-a.html
I needed a bar to go around my dry sump pump-
So I used a Panhard bar and angle iron
Old Apr 22, 2021 | 04:58 PM
69ttop502's Avatar
69ttop502
Get a hold of 76strokervette here on the forum. He makes a good one. I have it on my car.
Old Apr 22, 2021 | 05:09 PM
60 SHARK's Avatar
60 SHARK
Thanks Richard, did see that today as I was searching, I have Small Block, and hopeing for plenty of room as most have experienced.
Looking forward to building it, 😄
Was planing on building rear strut rods also but couldn't beat priceing and next day delivery from Summit on the Global West strut rods. Very happy with those, 👍
Old May 1, 2021 | 12:25 PM
74contraption's Avatar
74contraption
My hillbilly homemade one on my 74
To Spreader Bar~Where to Purchase?
