idle surge 81 corvette
Old Apr 25, 2021 | 03:13 AM
okstrat's Avatar
okstrat
Default idle surge 81 corvette
Bought a drivable but needs a ton of TLC 81 corvette in December. Car was turtle slow and ran rough. Wouldn't stall, but came super close.
So in order to make the car run a bit better, I have:
replaced cap and rotor
replaced plugs and wires
found and replaced some bad vacuum lines
new air filter
everything is better, car is still slow but maybe angry turtle slow now. However, I can't get rid of this idle 'surge' thing. Here's a video - I did not blip the throttle, car did that on it's own. I was in drive with the brakes on. What's left that this could be? Fuel filter? Carburetor? It does have the stock L81 engine and computer setup including the carb. Brief video attached to show what I'm talking about.
File Type: mov
Old Apr 25, 2021 | 04:59 AM
derekderek's Avatar
derekderek
quadrajet? does it have an electrical plug on the carb? the computer controlled carb was a bad idea that did not age well. you need to replace the carb, distributor and unhook the ecm.
Old Apr 25, 2021 | 10:39 AM
Roy W.'s Avatar
Roy W.
Disabled by request 8 JUN 2025
If original, the catalytic converter is plugged. Dump it and go with true duals.
Old Apr 25, 2021 | 11:38 AM
Mrvettenick's Avatar
Mrvettenick
You really need to hook a scan tool to see if there are any codes, and to look at sensor values to see if anything is out of spec, and to see if it can go into closed loop.. My 81 runs fine with everything hooked up.The sensors I would look at is the coolant sensor. map, tps and O2 for starters. Have you replaced the thermostat with anything other than a 195?
Old Apr 25, 2021 | 11:20 PM
okstrat's Avatar
okstrat
Yep, it's a Quardajet with all the computer controlled crap on it.
Never even thought of a plugged catalytic converter. Thanks! It's likely original from how everything looks under there.
Not sure if the thermostat is a 195 or not, I've never changed it but only owned the car a few months. Some of the stuff I've found / fixed has amazed me so far. Last owner wasn't much of a DIY guy, or at least he wasn't good at it.
Thanks guys! Good info.
Old Apr 26, 2021 | 03:02 AM
Mrvettenick
A quick check if you think it's the converter. Rev the engine to 3000 and hold it, if the converter is bad you will see the rpm's drop from the converter choking the engine. If that happens, take out the O2 sensor, then run the same test. If the rpm's hold, then it's the converter.
Old Apr 26, 2021 | 07:16 AM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
If the car is sluggish......first thing to do is set the base timing. Find an 81' repair manual for the procedure as it requires you disconnect a wire to set it.
Set timing first.
Post a pic of the engine with the air cleaner removed.
Jebby
Old Apr 26, 2021 | 11:39 AM
Mrvettenick
If you want to check/set timing. just look at the emissions label on the hood. If it's not there, just post, and I will lay it out for you.
Old May 18, 2023 | 01:35 PM
GerryLP's Avatar
GerryLP
1st Gear
new air filter
it’s been a couple of years… what did you figure was causing the “unusual” surge?
GerryLP 😎
Old May 22, 2023 | 12:04 PM
vettebuyer6369's Avatar
vettebuyer6369
GerryLP 😎
Poster hasnt logged in in a year.
To idle surge 81 corvette
