Kickdown Cable?
Old Apr 26, 2021 | 03:20 PM
titanle's Avatar
titanle
Default Kickdown Cable?
Does a TH350 require a kickdown cable? From what I read on the holley ultra street avenger manual it says the kickdown is only necessary for the TH200/TH400 but not for TH350. But doing some online research I see a bunch of sites and youtube vids showing installation of a kickdown cable/bracket on a TH350.
Im confused!
Old Apr 26, 2021 | 04:56 PM
lakerider57's Avatar
lakerider57
Kick down cable/bracket is used on TH350 (at least it was used for 1980)
Richard
Old Apr 26, 2021 | 05:07 PM
lars's Avatar
lars
The TH350 uses a kickdown cable attached to the lower extension of the throttle lever - the kickdown will not operate without it. The TH400 does not have a kickdown cable - it uses an electrical switch on the throttle linkeage or gas pedal.
Old Apr 26, 2021 | 11:47 PM
titanle's Avatar
titanle
So I guess I was missing it all along. My previous carb only had a throttle cable connected to it and now so does the new one.
that means I have no passing gear at wot correct?
Old Apr 27, 2021 | 02:55 PM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
My guess is that you have a TH400 trans......the switch is down by the gas pedal.
Jebby
Old Apr 28, 2021 | 11:33 AM
titanle's Avatar
titanle
you are correct, i realized the pan is the th400 shape not th350.....silly me
To Kickdown Cable?
