Make it quiet, please
Old Apr 29, 2021 | 10:05 AM
Yadkin's Avatar
Yadkin
Default Make it quiet, please
That was the request from the wife, so I'm trying to make my '81 quieter. I started with new mufflers- the old ones were completely shot. Now I'm working on the interior to reduce the road noise.
I installed a Hushmat "trunk kit under the factor sound mats. There was enough material to cover the floor from the battery box on back, then up the vertical rear panel and halfway up to the steel plate above that. Then the wheel wells. Leftover pieces went on the vertical sides below the wheel wells and the slanted panels behind the seat. Then I used some hardware store material over the slanted panels.
The speaker kits are still drying- not yet re-installed.
When I took out the factory mats I soaked them with Simple Green, rinsed them and dried them in the sun. The sides are barely intact and I stipped off the plastic film, put them back and used about a mile of duct tape to reinforce them.
Anything I'm missing here?
Old Apr 29, 2021 | 10:10 AM
Yadkin's Avatar
Yadkin
Sure am, missing the picture.
Old Apr 29, 2021 | 10:13 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
How's your weather stripping? You can get wind noise if the weather stripping is getting old.
Old Apr 29, 2021 | 10:21 AM
Yadkin's Avatar
Yadkin
Not much wind noise, and I redid the T-top seals last year. Seams to be a just road noise coming from the rear section.
Old Apr 29, 2021 | 10:44 AM
interpon's Avatar
interpon
should be a big difference!
i used some alum foil to fix my old insulation in front.
i would also consider running the lowest tire pressure listed on door.. 30psi for an 81? i run like 24 front and 28 rear..and big difference in harshness.. not sure where you are at now.. over 2 tons here!
Old Apr 29, 2021 | 12:48 PM
GTOguy's Avatar
GTOguy
Used Frost King on a '67 GTO restoration about 10 years ago. Was $21 for enough to do the whole car....used a tire patch wheel to get the corners and a roller to stick it down elsewhere. Did the roof under the headliner and the inside of the doors as well. Really made the car quiet and tight.....much better than factory. Dyna-mat would have cost about $800-$1000 to do the same job.
Old Apr 29, 2021 | 01:05 PM
BLUE1972's Avatar
BLUE1972
used the same on my 85, worked well
Old Apr 30, 2021 | 01:54 PM
Yadkin's Avatar
Yadkin
I've used similar stuff in the past with good results, with the exception of overhead or vertical applications because it didn't stick as well as Dynamat. The material for this job is HushMat, about 1/2 the cost.
Old Apr 30, 2021 | 01:56 PM
Yadkin's Avatar
Yadkin
Results are in. I added a 1/2" dense foam on top of the OE cardboard. Then I added a layer of some hardware stuff under the driver's seat, where there was nothing. Now the only road noise I hear is from the front.
I'd grade this job as a B-, maybe a C. Better than the F that I was working with.
Old Apr 30, 2021 | 03:18 PM
ddsmith60's Avatar
ddsmith60
Originally Posted by Yadkin
Now the only road noise I hear is from the front. .
I was afraid of that. Crank up the tunes
Old Apr 30, 2021 | 07:00 PM
Yadkin's Avatar
Yadkin
Waiting on new speakers. The original ones were in the back and one was chewed up by a mouse. Thankfully he had been a short term resident. In the front, the right was original, completely dry rotted, and the left was a POS from radio shack.
Old Apr 30, 2021 | 07:07 PM
7t9l82's Avatar
7t9l82
Have your wife take a ride in mine, she will never complain again!
Old Apr 30, 2021 | 07:49 PM
Bikespace's Avatar
Bikespace
Yup! Sidepipes and earplugs. Windows down, T-Tops off.
I used Hushmat and Reflectrix in my wife's tame 79 auto. It helped, a lot, but she's an actual car enthusiast. The car has true-duals (with cats), and isn't very loud.
Old Apr 30, 2021 | 08:49 PM
Yadkin's Avatar
Yadkin
Mine had a single cat and a Y-to-Y pipe. I killed the cat, now it has an X pipe.
Old May 1, 2021 | 07:32 AM
Reaper19's Avatar
Reaper19
Yadkin did you remove the Y Pipes and cat or just make some cuts and add in the x pipe? Do you have any pictures?
Old May 1, 2021 | 08:23 AM
Yadkin's Avatar
Yadkin
https://www.corvetteforum.com/g/picture/20886803
Old May 3, 2021 | 07:33 PM
60 SHARK's Avatar
60 SHARK
Yea, next step is ear buds or ear plugs,,,,,Good luck with that,,,LOL,,,
Old May 3, 2021 | 09:07 PM
EarlyC34me's Avatar
EarlyC34me
Parts Sherpa
I used Koolmat
To Make it quiet, please
