Cooling system questions
Old May 13, 2021 | 09:55 AM
  #41
Jebbysan's Avatar
Jebbysan
Dr. Detroit
What is your timing setup at? Hook the vacuum advance to full manifold vacuum.....that alone may solve your issue......yours is not hooked up and needs to be.
Jebby
Old May 13, 2021 | 12:03 PM
  #42
zblackz06's Avatar
zblackz06
Jebby
You are correct but the previous owner said that he changed either the springs or the weights in the distributor so I dont know how that will affect things.
Old May 13, 2021 | 12:09 PM
  #43
Jebbysan's Avatar
Jebbysan
Dr. Detroit
It won't....vacuum advance is a whole different animal.....vacuum and mechanical advance work together, having it unplugged is not correct. Vacuum advance will affect coolant temps at idle and light part throttle cruising.
E-mail Lars Grimsrud for his timing papers and read them...... V8fastcars@msn.com.
Jebby
Old May 13, 2021 | 12:34 PM
  #44
augiedoggy's Avatar
augiedoggy
[QUOTE=Sayfoo;1603436273]
Originally Posted by augiedoggy
Curious? Did you try electric fans
No, I did not. 210 deg is not a problem with good oil.
The biggest problem is cabin heat in the summer time.
Thanks.. This
Originally Posted by Sayfoo
I have tried everything ever mentioned on CF to lower the temp,
is the only reason I asked since its pertinent to what was being discussed and one of the most popular modifications done here beside a lower temp thermostat to lower temps under the hood.
