Troubleshooting Taillights
Old May 10, 2021 | 01:57 PM
ThatHazardousGuy's Avatar
ThatHazardousGuy
Default Troubleshooting Taillights
I was changing the sparkplugs a 72 I just recently picked up and accidentally hit the thing circled in red in the attached picture with my ratchet. When I did it shot sparks and then I realized I probably shorted something out. Well now I have no taillights / turn signals in the rear and my gauge lights dont work. All the lights up front are fine. The fuses don't look blown but I have not pulled them out yet to test. (that's next)
Can someone tell me what this thing is so I know what I hit as I start tracking down what happened?
This is on the driver side of the engine bay directly infront of the brake master cylinder and behind the alternator.
Thanks in advance.
Old May 10, 2021 | 02:07 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
That's the horn relay/key buzzer and a major wiring junction under the hood. If you saw sparks, but probably blew a fuse or two.
Old May 10, 2021 | 02:17 PM
ThatHazardousGuy
Thanks for the info. That explains a lot now. I haven't messed with the electrical much since I got it since it all just worked. lol
Guess I'll go digging into fuses. The relay itself still seems to be fine since the horn still works properly.
Old May 10, 2021 | 06:37 PM
HeadsU.P.'s Avatar
HeadsU.P.
Just behind that black rubber boot is another 4th of July hotspot for tools to touch. YIKES !
Old May 10, 2021 | 07:05 PM
Peterbuilt's Avatar
Peterbuilt
Check the 'fusible' links.
https://docs.google.com/viewer?a=v&p...GE5N2EzZGI2Mjc
Old May 10, 2021 | 07:15 PM
derekderek's Avatar
derekderek
wouldn't that pop the fusible link at the starter? and that should shut down the whole car. and buy an arc welder if you want to start welding...
Old May 10, 2021 | 09:09 PM
ThatHazardousGuy
The only thing that's affected right now that I can tell is the running lights in the rear.
I checked all of the fuses under the dash and they're fine.
I'm gonna check grounds for the rear lights.
Brake lights and turn signals are really dim in the back. When I have the headlights on and use the turn signals they're really slow flashing. I know that to be a current issue.
Thanks guys for throwing info out.
Old May 10, 2021 | 10:24 PM
ThatHazardousGuy
I have started a new thread for what I believe to be the underlying problem here. I have identified a few wires above my driver side muffler that appear damaged or not grounded/plugged in... I'm trying to identify them, now. I wonder if I damaged these while installing a new gas tank over the weekend.
https://www.corvetteforum.com/forums...post1603434080
Old May 11, 2021 | 08:07 AM
henrikse's Avatar
henrikse
Like peterbilt advised it will be a fusible link. If you look at the picture you posted the blk/wh wire is a fusible link. It is a wire with rubber on it like that. It is simply a gauge wire with one 4 times smaller in the rubber. When excess current flows it burns the smaller wire. Sometimes you can see it burnt out and sometimes you have to check on eacj side of the wire with test light
Old May 20, 2021 | 12:34 PM
ThatHazardousGuy
Opened the harness and reran all my grounds in the rear of the car and now the lights operate properly. Thanks guys for the assistance.
To Troubleshooting Taillights
