What's draining my battery?
Old May 18, 2021 | 12:50 PM
rscanlon68's Avatar
rscanlon68
1st Gear
Default C3 undetectable battery drain
Originally Posted by Wdoland
If my 78 Corvette sits for 2 days the battery is drained. Disconnected cables put a test light on the positive terminal of the battery and the disconnected negative cable and there is a light. Ran a meter across every fuse in the fuse box and there is no drain. Where could it be coming from?
I had the same issue forever...ran into an old friend who rebuilt alternators, asked him if the alternator could be the drain. He said absolutely and to bring it to him but to bring the little box that sits on the inner fender too ( think was volt box) Any way the drain was in that little black box, he rebuilt both to keep original and the drain is now a closed issue!
Old May 21, 2021 | 08:37 AM
Wdoland's Avatar
Wdoland
Problem solved!
it was the wire to the cigarette lighter that was causing the short. It came off its connection and was touching ground. I should be good to go now. Thanks to everyone for your help and advice. Side note- I did need a new alternator anyway since the old one was making grinding noises when turned by hand
Old May 21, 2021 | 11:34 AM
CW-C3-Op's Avatar
CW-C3-Op
Congrats! It always feels good to get to a conclusion. And thanks for posting what happened. Ya just never know when your problem and fix will keep some C3 enthusiast at their wits end from pushing their car off a cliff!
