I have pretty much determined my engine to be a real 1968 L79 327/350- with HP suffix (A/C and P/S), built in Summer of 68 (castings are all F,G or H), 2.02/1.60 valve 186 heads(No screw-in studs/guide plates), 151 cam, forged 11-1 pistons, forged large journal crank, long sump pan, standard bore, bearings dated 5/68.
My issue still lingering is the intake combo. I can only find one source that says the engine would have a 3914678 manifold, and it's topped with a 7028207 DA Q-Jet, which sources say is 327/300 only. I know there were plenty of mistakes made through the years, but has anybody ever seen this carb/intake on an L79? How about the big valve heads without guide plates?
186 Big Valve heads are correct and came on the L-46 350/350 as well. 68' was the first year for the Q-Jet and there is only one Q-Jet manifold available.....low rise, cast iron non-EGR. 1966-67' L-79's had an aluminum intake and a 585 cfm Holley single feed carb.
1968 is also the only year for the large journal 327. I have a 1968 327/300 outside here and it has 186 small valve heads and the same intake and carb.
like said above. 68 L79 used cast iron manifold. I’m not 100% sure if 350 and 300 hp used same manifolds. I’m guessing g maybe they do. So a carb swap would be easy
I got that, but it just seems odd to me that it would have been changed because everything else looks correct- the carb even has the correct date to go with the rest of the engine.
I just saw a post by Lars--"7028207 Chev 68 327/350 MT VETTE 71 46 7036019 AN 2.2973 3.4283"
HP = 327/350HP 3914678 is a engine block not a manifold 7028207 should be a 7028219 Friend has a late July L79 4-speed original owner his carb is 7028219
Intake 3919803 till June 68 Late June changed to 3927184
My 68' 327/300 has the 3919803 manifold on it for what it's worth.......
Looks like the L-79 was cam, valve size and compression only.
[QUOTE= there is only one Q-Jet manifold available..../QUOTE] There are many that will disagree with that--like the people with 3919803 intakes. And when you search, you find them with and without the oil filler tube hole, yet they have the same casting number--just like the 186 heads share the same casting number whether they have 1.94 or 2.02 valves, and whether or not they have screw-in studs and guide plates!
Originally Posted by bowtie0069
"Carb is def 300 hp version" I got that, but it just seems odd to me that it would have been changed because everything else looks correct- the carb even has the correct date to go with the rest of the engine.
That's correct - the 7028207 carb was used on 327 and 350 manual trans Vette engines. Standard versions. Although no 350 Vettes were built in '68, the Rochester book shows the carb application for both 327 and 350. The Nova did use the 350 in '68, and the Rochester Bulletin lists the Nova with the Vette info for this carb. The L79 was the "H.P." engine, and used the Corvette-only, L79-only 7028219 carb. The "207" carbs were not used on L79.
On my carb listing sheet, you will notice that carbs used on multiple cubic inch displacement engines are listed with a "split" application. Carbs that were used on both 396 and 427 engines are shown as 396/427. Pontiac carbs used on 350's and 400's are shown as 350/400. This does not mean there was a 350 with 400 horse... Carbs used specifically on the high performance engines are annotated with "hi perf."
Lars
My 68 L-79 came with a 7028207 Carb. The inlet stripped out in 1984 when I rebuilt the engine. The only replacement Chevy had was a 1969 350/350hp quadrajet for a Corvette...number 7029207...still on my 50 years owned Vette.
1968 Corvette Assembly manual also shows 7028207 for carb spec.
If anyone can provide positive evidence that the official, released, published Rochester tech and spec data, as approved by General Motors, is wrong, I'd like to see it so I can make corrections to my historical spec records.
Lars
