Open Air Cleaner
Old May 24, 2021 | 10:26 AM
  #61
REELAV8R's Avatar
REELAV8R
Originally Posted by augiedoggy
The L82 dual cai could support more than 400hp though from what I remember reading about here in another thread..
I imagine it could. I just had to add two 2” ducts to my existing L-48 intake to support my 440 HP. This 440 HP is a sea level rating however and I never actually see that power in operation.
it’s likely that only 2 additional ducts support my engine’s intake needs because I’m not operating at sea level and the engine is simply unable to draw enough air to overwhelm the intake volume I have.
Air density has to do with humidity and barometric pressure also. The reason I talk about the intake temps is simply because that one is the within our control on a normally aspirated engine.
some pressure could be added if you had a CAI system that took advantage of ram air. Of course only at higher speeds.
