Inaccurate reproduction speedometer
Old Jun 3, 2021 | 01:19 PM
vegahigh's Avatar
vegahigh
2nd Gear
Default Inaccurate reproduction speedometer
Hello,
I have a strange one . Frame off resto-mod on a 68 vert, Gages were faded and stained, so I ordered replacements from one of the normal vendors. The first speedo was in a GM marked box, and looked fine. 2 years later on fire up, on a lift with the wheels in the air, (TKO600 BTW) it immediately went to full scale and stayed there. Dead along with the Odo. Over the winter I bought a new speedo, again it shows up in a GM marked box, looks nice as did the first one. Installed along with new cables since I was there anyhow. Now $600 bucks in.
Well, this one works, sort of. The trip odo registers twice the value of the main odo, and at low speeds it reads 10 slow, and at interstate high speeds it is 20mph high. I can understand always being off one way or another, but not both. I have 250 miles on the recent speedo. Thoughts?
Thanks in advance. - Joe
Old Jun 3, 2021 | 02:01 PM
Barry's70LT1's Avatar
Barry's70LT1
Originally Posted by vegahigh
Hello,
A couple of years ago my original speedo failed (gear worn out). I purchased a new speedo from a well known supplier. It came in a Delco box. Like yours, the trip recorded miles at a different rate than the main Odo. I don't recall if the MPH was off. I had that speedo replaced under warranty. The next one was not a Delco speedo, the Odo worked fine and was accurate. However the MPH was not too accurate.
At this point I repaired my original speedo. It needed a new first gear (input with magnet) and a new second gear. Since the first gear came from another speedometer, I needed to calibrate the speedo. So far it's been working well for the past couple of years.
I tried to calibrate the warranty replacement speedo and there is not enough adjustment to make it accurate. I suspect the magnetism has faded, as the speedo MPH shows slow on calibration.
