Does the car still utilize the column ignition?
If it does, and you cut this bracket off instead of wiring it in the up position, vibration will rotate it downwards. Then the ignition will tumbler will not rotate to the start position.
If the car is completely built for off road and uses a remote start button or different type of ignition, then this part will not matter.
It's a *****-out racer. No ignition key. Just a kill switch and a starter button on the dash.
