Compressor Pulley Rim Locking Washers
Old Jun 8, 2021 | 08:00 PM
Mikey1339's Avatar
Mikey1339
Default Compressor Pulley Rim Locking Washers
I need to replace my failed compressor clutch bearing. Where does one buy the disposable locking washers for the compressor pulley rim mounting screws? Isn't the locking nut on the front of the compressor clutch also 1 time use? My original washers might be re-usable but I am not sure if they broke the pulley rim loose or if the pulley rim was loose because the bearing died first. I would rather just get some new ones....
Old Jun 10, 2021 | 02:24 PM
TimAT's Avatar
TimAT
If my memory serves, the clutch plate on the front of the compressor has a lock nut. Remove that nut, then a puller to remove the clutch plate. Then there is a snap ring that holds the pulley bearing. The front seal can also be removed without removing the pulley with a tool that locks into it.
The lock washers you speak of has me at a loss. I don't recall them.
Old Jun 10, 2021 | 06:49 PM
Mikey1339's Avatar
Mikey1339
The pulley rim is held on by 6 mounting screws that tighten down these weird bent up washer things.
Old Jun 12, 2021 | 01:20 PM
TimAT's Avatar
TimAT
A6 Service manual.
If you have an R4 compressor, you may be looking at #3 and #4 in this picture.
GM R4 Compressor Parts - Bing images
Old Jun 13, 2021 | 01:54 PM
Mikey1339's Avatar
Mikey1339
Yup those are them. Don't know where to buy them.
To Compressor Pulley Rim Locking Washers
