What might go wrong?
Old Jun 10, 2021 | 01:35 PM
wwiiavfan's Avatar
wwiiavfan
Default What might go wrong?
My '71 has factory air but it the compressor was disconnected from the wire harness when I got it. No idea of the aircon system status. Now I'm curious if the air actually works.
Some PO put an incorrect 37 amp alternator on.
So if I reconnect the compressor with that smaller alternator, what might happen? Possibly overheat/burn up the alternator? (which isn't bad as it would give me an excuse to get a 94 amp for running electric fans, lol)
Old Jun 10, 2021 | 02:30 PM
TimAT's Avatar
TimAT
Unless you have documents that prove it's a 37 amp alternator, I wouldn't bet on it, regardless of the stampings on the case. GM used the bigger alternators (bigger amp output) thinking that running at night with all the load, headlights, a/c, radio, the output is needed. THe heat/ac fan draws a bunch on high. For your testing, you can run what you have without any ill effect.
Old Jun 10, 2021 | 03:02 PM
derekderek's Avatar
derekderek
rebuilders clean up and paint any alternator frame and resell them. very few 10si type alternators have never gone thru a rebuild shop. and they would only rebuild a specific one if asked. and they would most likely not leave it at that low an output. a guy with a 69 corvette wants the correct numbers and date code. he ain't gonna bitch cuz it works too good to be OEM correct. and ac doesn't draw that much power unless electric fans are involved. what might go wrong? lots, but not because the alternator is too weak.
Old Jun 10, 2021 | 03:11 PM
Redvette2's Avatar
Redvette2
Isn't the AC's electrical power being used just to pull in the compressor clutch and run the dash ventilation fan. The spinning compressor is running off of the engine. Seems like it should be OK.
Old Jun 10, 2021 | 03:38 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
If the A/C draws more than the alt makes then worry.
Seems the issue is how good or bad the compressor is.
Old Jun 10, 2021 | 05:02 PM
Hammerhead Fred's Avatar
Hammerhead Fred
Old Jun 10, 2021 | 05:20 PM
augiedoggy's Avatar
augiedoggy
GM upped the oem alternator from 42 to 60amps for the AC... That said I would be curious to know what it actually draws in current as well...
My money is on the AC leaking and needing service... I doubt it was disconnected for any other reason. mine was the same way.
Old Jun 10, 2021 | 05:25 PM
derekderek's Avatar
derekderek
ac clutch is 2 to 4 amps. blower is about 15 amps. can't hurt to have the alternator bench tested.
Old Jun 10, 2021 | 05:30 PM
augiedoggy's Avatar
augiedoggy
still for matters of testing the ac to see if it works, he can do this without upgrading the alternator.. worst case scenerio is if left on too long it will start to drain the battery but it would take a while.. much longer than he needs to test the ac. just putting a volt meter on the alternator output and seeing if the volts drop below 13 would tell him if the alternator is keeping up or not.
Old Jun 10, 2021 | 06:19 PM
Mrvettenick's Avatar
Mrvettenick
His console gauge will tell him everything. If it drops below 12 volts, then you know you've exceeded the supply. I would say it would be close, As long as you don't drive at night in a rain storm.
Old Jun 10, 2021 | 07:11 PM
Peterbuilt's Avatar
Peterbuilt
Good guess!
Old Jun 11, 2021 | 02:50 PM
0311 jarhead's Avatar
0311 jarhead
Veteran: Marine Corps
Check to see if was converted to 134. R12 is hard to get
Old Jun 11, 2021 | 03:43 PM
Mrvettenick
I would assume that it hasn't to be safe, and start from scratch, including the oil.
To What might go wrong?
