CFM through an L68 Tri-Power.
Old Feb 27, 2014 | 10:40 PM
FlyLS6's Avatar
FlyLS6
Default CFM through an L68 Tri-Power.
Ok...so somewhere a long time ago I saw a thread that the L68 tri-power would actually flow about the same as a 4 barrel flowing ~906 CFM. I have no idea about the math related to the theoretical flow vs equivalent 4 barrel flow.
The l68 cam wasn't particularly "stout", but the L68 wasn't such a bad running engine as street performance engines go; I had a '69 about 15 years ago and thought it ran pretty good, for what it was.
Yet, going to the CFM calculators, 906 CFM is way over what most of the CFM calculators would give as the CFM requirement on such an engine. So I'd expect the L68 would run pretty flat, so to speak.
How did the engine run as well as it did, if in fact the calculators are "correct", which would imply the L68 was grossly over carb'd. Of course, it may be that the end carbs weren't opening fully, being vacuum operated, but I can't believe GM would actually release a motor tuned like that.
Popular Reply
Feb 28, 2014, 11:04 AM
lars's Avatar
lars
The cfm flow numbers and ratings on the Tripower cannot be directly compared to the cfm ratings of a 4-barrel carb, and there are some other factors to consider as well, making the "1000 cfm" rating questionable and somewhat irrelevant.
First, keep in mind that the SAE standard for testing and rating 4-barrel carbs is at 1.5 inches of Mercury, while the test pressure for 1-barrel and 2-barrel carbs is 3 inches of Mercury. This higher delta test pressure (twice the delta pressure) for the 2-barrel carb makes the 2-barrel appear to flow much higher, and the numbers for the 4-barrel cannot be compared to the numbers for the 2-barrel. The reason for this pressure difference in the rating is that it is assumed that a 2-barrel carb is used on a modest passenger car, which will pull vacuum even at WOT, whereas a 4-barrel carb used in a performance application will pull very little vacuum at WOT. For racing purposes, the flow ratings get even worse, since a properly-sized carb for a racing engine will pull almost no vacuum at WOT. On the other end of the spectrum, the little 390 NASCAR carbs, used at extreme rpm, pull so much vacuum at WOT that the carb actually flows about 3 times its "rated" flow rating. The large 2-barrels on the low-rev'ing 427 will not be exposed to anywhere close to 3" Hg vacuum at WOT, and will not, therefore, flow anywhere close to the 1000-cfm rating.
To add a little more confusion to the whole "cfm rating" thing, most flow benches in the racing industry (such as those used by Holley and Demon) measure dry air at low pressure drops (about 10 inches of water) one venturi at a time. This result is multiplied by a factor to arrive at what that bore would flow at a higher vacuum (i.e. 1-1/2 or 3 inches of mercury), then that figure is multiplied by the number of barrels to get the C.F.M. rating. This rating is usually much higher than it actually is, since the interaction between the barrels prevents them from achieving their individual flows once they are working together, so use of the manufacturer's "rating" is not a reliable yardstick for running the common "carb sizing" calculators: The calculators usually end up showing that the engine needs a very small carb, when, in fact, the engine, when used in a performance application, can make good use of a carb significantly larger that what the "calculators" would indicate.
So knowing all this, let's take an educated look at the 2-barrel carbs on the 427 Tripower: The 2-barrel carbs are rated at 350 cfm. Times 3 equals 1050 cfm. Wow.
Now, consider that those carbs achieved that rating with twice the test pressure of a 4-barrel carb. The flow through the carb is not linear with pressure, so the 350 carb will probably flow a little over half that at half the delta-P, so give it the benefit of doubt and say it will flow 75% of its 3-inch rating when tested at 1.5" of Hg. That puts the carb at a "4-barrel equivalent comparative flow" of 262 cfm. 262 times 3 is 787 cfm... Sounds just about perfect for a street-rpm 427.
To create additional disadvantage to the Tripower, the low-profile air cleaner, fitting tightly over the carbs, creates additional flow restriction and decrease in total cfm flow. Also, 6 barrels simply cannot feed 8 cylinders as evenly as a single center-mounted 4-barrel. So although the Tripower looks fantastic, and was a great marketing tool for the Corvette Performance image, fact is that a single 850 cfm 4-barrel will significantly outperform the "1050 cfm" Tripower when set up correctly on a good manifold.
But thus, the 427 can use a "1050-cfm" inlet system...
Lars
Old Feb 27, 2014 | 11:12 PM
68/70Vette's Avatar
68/70Vette
My memory is pretty old, but I think a 3X2 with a rectangular intake port could flow a little over 1000 cf/m. From the factory, you couldn't get all 3 carbs to open up by just putting the peddle to the metal...my understanding...The outboard carbs responded to mostly vacuum, the center carb responded directly to the driver's throttle command. Once you floor boarded the center carb, the outboards would open up and if you kept the pedal to the metal, the outboards would open up fully also. Maybe a 3X2 expert can crisp up this dialog a little.
Old Feb 27, 2014 | 11:15 PM
7T1vette's Avatar
7T1vette
The maximum capacity of the tri power carbs will not actually be used. Of course, you can always 'stuff' more fuel into an engine than it needs. But, fuel flow out of any carb is dependent on the vacuum level the engine is producing. The engine can only demand so much airflow at its redline; I'm sure that would be less than the capacity of the tri-carb system could handle.
Old Feb 28, 2014 | 10:02 AM
FlyLS6's Avatar
FlyLS6
Default Tri-Power
So it seems the experience from some L68 owners with regard to their observations would be in order. If the motor pulls enough air to fully open the end carbs, presuming enough spring resistance to the diaphragms exists to provide a real world and valid test, it would seem that the greater CFM capacity isn't being wasted.
I wish someone would bring one to the next "Dyno Day" at the local dyno shop so as to see what's actually going on with them. That would also give the A/F mix info.
Old Feb 28, 2014 | 11:04 AM
lars's Avatar
lars
Lars
Old Feb 28, 2014 | 11:58 AM
gkull's Avatar
gkull
The only addition to what Lars indepth post said: I messed with a tripower setup for years. The idea was good, but the intake manifold design creates a difference in cylinder to cylinder filling. That can also be said about the low rise two four barrel units.
they do have the eye apeal.
Old Feb 28, 2014 | 02:06 PM
billla's Avatar
billla
St. Jude Donor '14
Lars, thanks for your deeply insightful, experience-driven post
-----------------------------------------------------------------------------^^^ (really good beer)
I had dreams at one point of building a '68 Chevelle convertible with a tri-power, just for the OMG factor of opening the hood...
Old Feb 28, 2014 | 02:51 PM
7t9l82's Avatar
7t9l82
i had a 440 six barrel A12 road runner( which had a similar Almost Identical ) system . it ran better with an 850 holley. they can be made to run well but it takes some work.
Old Feb 28, 2014 | 05:40 PM
Super6's Avatar
Super6
The straight math is 350 + 2 x 466 = 1282cfm. That divided by the square root of 2 is 906.6. These sizes are true for the L71, but I think the 400HP engines had the same carbs. I didn't look it up though.
The Mopar cars were 350 + 2 x 500 = 1350.
Old Feb 28, 2014 | 06:02 PM
TedH's Avatar
TedH
Lars
Lars, when you get around to 'writing the book', I want a copy.
Old Feb 28, 2014 | 06:16 PM
7t9l82's Avatar
7t9l82
mopar rated the center carb @ 500 c.f.m
Old Feb 28, 2014 | 09:19 PM
v2racing's Avatar
v2racing
Lars
I agree 100% with this too. The 3 deuce setup has terrible runner design. Modern 4 barrel manifolds have much more even cylinder fill, especially the single planes. The 3 deuces are still selling the cars born with them though!
Old Feb 28, 2014 | 10:23 PM
lars's Avatar
lars
It's still rated at the SAE 2-barrel spec delta-P, so that 500 cfm rating is at 3 inches of Hg. It cannot be directly compared to a 4-barrel rated at the same cfm at 1.5 inches Hg; it's significantly less. That's the point.
Lars
Old Feb 28, 2014 | 10:28 PM
FlyLS6's Avatar
FlyLS6
Wow. It doesn't get much better than that. I knew my major should have been engineering instead of trying to proof that on a continuous line there are an infinite number of points between any two given points. Don't ask.
This is the crux of why I started this thread: "The calculators usually end up showing that the engine needs a very small carb, when, in fact, the engine, when used in a performance application, can make good use of a carb significantly larger that what the "calculators" would indicate. "
The calculators that everyone know about tell me I need between 750 and 800 cfm, "depending". And with an 770 SA, I figure that's about where I am. The problem is, I seem to observe engines running larger CFM than the calculators would call for, successfully. I realize all the particular can make a big difference...cam, exhaust, compression, intake and head design, etc. What came to mind was the 390 vs 400 HP 427s, in which the "flow" of the tri-carb set up seems to be totally out of line with the calculators, but the engines seem to run and perform fine, as do the 390s - for what they are (as I felt my old '69 did). Lars, of course, solved that one. (To clarify, I have no interest in a tri-power set up; I was just using them in trying to logic this out)
But, the further comments remind me that it's "just money", and trying something a little larger would answer the question re my build once and for all. :-) I wonder if I can get a volume discount on dyno runs.
Old Feb 28, 2014 | 10:46 PM
v2racing's Avatar
v2racing
Lars
The whole CFM thing with carbs is really screwed up anyway. It takes one heck of a flow bench to flow a 4 barrel carb at 1.5"HG (20.4" water). A Superflow 600 bench will maybe be able to test a 600 CFM 4 barrel carb, but nothing beyond that. Any difference in the shape and design of the AC base plate, velocity stack, or having nothing on the top will heavily affect the outcome. What's on the outlet side will even affect the flow more. If the throats of the carb are just dumping into a large open area adapter to the bench it will have huge turbulence at the exit and hurt airflow. If you use something like a 2" HVC adapter that has a controlled expansion area, there will be far less turbulence and the flow bench will show a lot more flow. Flow the carb wet and it will be different too.
Old Mar 1, 2014 | 09:33 AM
Super6's Avatar
Super6
Lars
Which is why in my mind the big block to get was the L72 (427ci/450-425HP) with the good factory manifold and a single 4-barrel in the '66 Vette. Second on Muscle Car Magazine's 50 Fastest list.
Old Mar 1, 2014 | 12:43 PM
lars's Avatar
lars
That's exactly right. Which is why the carbs are tested on a single barrel only, and that number is multiplied by the number of barrels for total flow. As noted, this ends up being a very artificial (high) number, since the carb will not actually flow that number through each barrel due to flow interaction on the inlet side of the barrels. The other factors you mentioned also create an artificially high number, but the biggest deceiving thing about 2-barrels is the difference in the SAE test pressure, as noted, which gives them a cfm "rating" that's significantly higher than the same comparative rating for a 4-barrel: effectively, the unit of measure is changed, so you simply cannot directly compare the cfm rating of a 2-barrel carb to the rating of a 4-barrel.
Lars
To CFM through an L68 Tri-Power.
Old Mar 1, 2014 | 12:56 PM
scottyp99's Avatar
scottyp99
I have read that when 4-barrel carbs first came out, there were not any apparatus available that would read cfm that high, which is why they tested them at 1.5 instead of 3, and it just kind of became the standard that is used to this day. Any thoughts on this, anyone?
Also, I think that back before they had 4-barrel carbs, multiple carbs were really the only way to get more cfm for the bigger engines that they started building in the '50s, of which the 3-2barrel carb system was popular. These multiple carb system got quite a reputation back in the '50s, and by the time the '60s rolled around, with big 4-barrel carbs available, they still retained that reputation with old skool types, and still do to this day. Again, any thoughts on this, anyone?
Scott
Old Mar 1, 2014 | 02:14 PM
CA-Legal-Vette's Avatar
CA-Legal-Vette
Keep it coming guys. Very interesting post
Old Mar 1, 2014 | 02:16 PM
babbah's Avatar
babbah
I love 'em, always did, always will!
