Timing Mark Way Off?
Old Jun 14, 2021 | 06:04 PM
bluthundr's Avatar
bluthundr
Originally Posted by c3_dk
I was thinking about the same for my Z28 RS, when I set it at 18 degrees, the vacuum is only 12, and the engine is not happy.
When I set it at 28,the vacuum is 16, and the engine sounds happy.
I assume it the same problem I have, or that the chain set has different settings, and it was installed "not to zero"
Your chain may be off a tooth, or it may not be zeroed. Some timing sprockets have a square, circle, and a triangle on them which sets you up for different "built in" levels of timing advance / retard. Your cam may also be ground with a certain level of advance built in when it is at the zero mark.
Old Jun 14, 2021 | 08:08 PM
leigh1322's Avatar
leigh1322
Old Pro Solo Guy
Check the keyway and timing mark first. Almost straight line. My Z28 loved 18 initial and 36 total. Yeah vac around another 12.
Old Jun 15, 2021 | 01:24 PM
c3_dk's Avatar
c3_dk
Thanks both
Old Jun 15, 2021 | 01:26 PM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
delete
