Big cam vs. Vacuum
Old Jun 13, 2021 | 06:13 PM
0311 jarhead's Avatar
0311 jarhead
Veteran: Marine Corps
Default Big cam vs. Vacuum
Whats the biggest cam for a small block 383 roller cam build you were able to use and still have enough vacuum to operate lights and wipers
well in your C3?
Old Jun 13, 2021 | 10:49 PM
cv67's Avatar
cv67
St. Jude Donor '05
Id be looking for a vacuum number as there are small cams that can make poor vacuum and larger ones that do ok.
What are you considering putting in?
Old Jun 14, 2021 | 12:58 AM
0311 jarhead
Comp Cams 260XFI HR13
.560 .555 113* LS
210 218 @50
109 CL
Old Jun 14, 2021 | 07:32 AM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
.560 .555 113* LS
210 218 @50
109 CL
This cam will provide over 13 inches of vacuum in a 383.
Good vacuum is a plus for the headlights and/or wiper door to work but remember that it is only as good as much as the system leaks. I only pull 10 inches of vacuum but everything works fine as it is leak free.
Jebby
Old Jun 14, 2021 | 07:33 AM
SH-60B's Avatar
SH-60B
.560 .555 113* LS
210 218 @50
109 CL
I used a Comp xe268 on a 350. vacuum headlight doors worked fine.
Old Jun 14, 2021 | 07:48 AM
augiedoggy's Avatar
augiedoggy
comp xe 270 retro roller cam with 1.6 rockers here in a 355 and headlights work fine at idle or driving. Brakes too... Before this cam I had the lunati voodoo 262/268 cam and the everything worked about the same va vise the boost in power with the 270 cam is noticable even with the 3.08 gears still in the car. kinda wishing I went one step bigger now.. lol.
Old Jun 14, 2021 | 09:02 AM
HeadsU.P.'s Avatar
HeadsU.P.
What's the biggest cam . . . . .?
This is not a proper question. The proper question is what cam will work best for the engine, drivetrain and driving style I have. The vacuum estimate is secondary in your search.
Use the cam companies 800 numbers and give them a call with all your engine specs printed out in front of you.
Old Jun 14, 2021 | 10:44 AM
gkull's Avatar
gkull
.560 .555 113* LS
210 218 @50
109 CL
That's a very poor choice for a H-roller. Do you know that roller cams create motor vacuum with more duration than their flat tappet counterparts? The other problem with roller cams is the superior cylinder filling causing detonation at lite throttle cruising. My first 383 with 10.7 c/r had horrible detonation with a 232/238 .620/644 112 cam.
Old Jun 14, 2021 | 11:25 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
get the best cam you can and if it doesnt produce the vacuum you need, install a electric vacuum pump. Use a Hella vane style not a diaphragm style. Its loud with the motor off but its not noticeable with the motor running. I have one that came with a pressure switch so it is on /off demand as long as you use the one way valves
something like this
https://www.summitracing.com/parts/h...content=GSAPI1
Old Jun 14, 2021 | 11:47 AM
gkull's Avatar
gkull
Oh, the biggest that I use on a 383 is a custom billet steel 236/242 .644/.660 112 brakes and everything worked fine. It got the lazy head lights. I could turn them on in the garage and the first head light would pop up backing out and the second would slowly come up when I started driving down the street. At speed in the evening one would come up then the other. Brakes were never a problem.
If you think about it a L-82 rated at only 225 hp or something was a 222/222 on 114. So there is NO reason to go the way lower duration with a roller. Most cams in the advertisements are talking about 350 ci NOT 383 with much more TQ. I was truly amazed in my first drives of my 383 with a 232/238 roller
Old Jun 14, 2021 | 12:48 PM
0311 jarhead
Exactly my plan today. Was just asking what others were using so the cam company dont try to hype me there latest products or give me some bum dope.
Happened before and I was very unhappy.
Old Jun 14, 2021 | 06:39 PM
gkull's Avatar
gkull
Do you know the 383 C/R That is the determining factor with Dynamic Compression ratio and what size min cam duration that you can run.
Engine vacuum can be increased by idle rpm and timing
Old Jun 14, 2021 | 07:31 PM
bluthundr's Avatar
bluthundr
I had a Speedway circle track in mine and I could not operate the headlight doors. I switched over to the McSpeed electric kit for the headlights and just recently went to a milder cam anyway.
Old Jun 14, 2021 | 07:40 PM
HeadsU.P.'s Avatar
HeadsU.P.
Why would any cam company try to sell anyone the wrong cam? They have a rep to protect. Talk about shooting yourself in the foot.
They have the software that will be very accurate in determining exactly what cam is best for your needs. No hype, Just data.
Later you can chose from whom you wish to buy from.
Old Jun 14, 2021 | 10:07 PM
gkull's Avatar
gkull
Why? Because they hired people that make nothing for wages and don't know anything other than what comes out on the screen
Old Jun 15, 2021 | 01:18 AM
0311 jarhead
Does anyone know why its so difficult finding Crane cams website? If you click on their cranecams.com you get Comp cams website?
Old Jun 15, 2021 | 08:53 AM
HeadsU.P.'s Avatar
HeadsU.P.
I disagree. That is not how they became a multi-million dollar business.
Comp Cams is number one in sales and number one in respect for their products and the way they do business.
They didn't achieve that rating by hiring dummies.
Come on boy's its time to go out and get real.
To Big cam vs. Vacuum
Old Jun 15, 2021 | 09:03 AM
augiedoggy's Avatar
augiedoggy
Comp also bought out many others like Crane and Lunati.. They are becoming the "Holley" of the cam world...
Old Jun 16, 2021 | 07:05 AM
7t9l82's Avatar
7t9l82
And in most run of the mill cams they don't even grind their own cams anymore. Alot are ground by an OEM supplier, but they won't tell you that. That's another way they became million dollar businesses.
Old Jun 16, 2021 | 07:48 AM
HeadsU.P.'s Avatar
HeadsU.P.
Comp Cams has facilities in Miss, Tenn, ILL & Mich. They have 28 CNC machines at the factories that make long production runs of thousands of cams and other machinery for producing custom racing cams of 20 units or less. They have 250 employees and it takes ten workers to make a cam from start to finish.
This does not sound like they farm-out to me.
